Go to Post Our robot will use sensors to collect information about its environment, then discard that information and drive into a wall. - Jared Russell [more]
Unread 01-02-2013, 02:16
Katna.Grace's Avatar
Katna.Grace Katna.Grace is offline
AKA: Katherine
FRC #3132 (Thunder Down Under)
Team Role: Electrical
Katna.Grace is a splendid one to beholdKatna.Grace is a splendid one to beholdKatna.Grace is a splendid one to beholdKatna.Grace is a splendid one to beholdKatna.Grace is a splendid one to beholdKatna.Grace is a splendid one to behold
Re: Hall Effect Sensors
We (3132) are using hall effect sensors with a buffering circuit this year. We developed them in the off-season for our 2012 shooter wheels.
We use Hall Effect sensors from RS (http://australia.rs-online.com/web/p...-ics/7384743/).
We are mounting the board flat underneath our shooter wheel, and 'hanging' the magnets down off the wheel. The magnets are epoxied into a piece of aluminium hex stock that was turned to a taper and had a hole drilled in it for the magnet. A thread was then tapped into the other end of the piece, to mount it on the end of the bolt holding the wheel on.
When mounting them, make sure that the sensor itself can't move, so that it can't be sheared off by whatever it's measuring or drift away from the magnet.
I'm attaching a picture of the board, and a picture of our magnet mounts (before the pcb is attached), as well as the schematic for the buffering circuit. Let me know if you have any questions.
Name:	imagehall effect schematic.png
ID:	13743  Click image for larger version
ID:	13744  Click image for larger version
Katherine
Electrical
FIRST® TEAM 3132
Thunder Down Under
Sydney, Australia
Unread 01-02-2013, 12:59
electroken's Avatar
electroken electroken is offline
Electron Tamer
AKA: Ken Pontbriant
FRC #0230 (Gaelhawks)
electroken is a jewel in the roughelectroken is a jewel in the roughelectroken is a jewel in the rough
A useful gear tooth sensor that wires directly into a digital input is the Allegro Microsystems ATS667LSG. We like to use them when we need speed information but not direction information and we don't need the highest resolution. We also like that they're $6.
In the photo below an ATS667LSG is mounted to a carrier board and installed in the side of a Cim-u-lator gearbox, with its face about 0.03" from the output gear. It gives us a nice, clean 27 pulses per output shaft revolution. The sensor on top of the right motor is just posing for the photo.
Unread 01-02-2013, 13:36
How are you decoding the signal?
Unread 01-02-2013, 18:17
electroken's Avatar
Electron Tamer
AKA: Ken Pontbriant
That's a good question. I told the student writing the code what to expect for a signal, and he said "Yeah, I got this".
Unread 01-02-2013, 18:32
The decoding method makes a big difference in the quality of the signal, especially at high speeds (depending in the method used).
Could you ask him to join the discussion here?
Unread 01-02-2013, 15:12
BitTwiddler's Avatar
BitTwiddler BitTwiddler is offline
electronics/programming mentor
AKA: Mr Tanguay
FRC #1726 (N.E.R.D.S.)
BitTwiddler is on a distinguished road
Nice find! A few questions.
1. Where did you purchase them?
2. Did you wire them with the bypass and lowpass capacitors?
3. Do you have any data on how it performs on chain sprocket teeth?
Unread 01-02-2013, 16:33
MrForbes's Avatar
AKA: Jim
.....steel? aluminum?
Unread 01-02-2013, 17:00
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Steel. Gear Tooth Sensors have an embedded rare-earth magnet along with a hall effect sensor. They detect a change in the magnetic field that you're not going to see with a non-ferrous target.
EDIT: Also, Digikey has 22,690 in stock. Better order quick before they run out.
Unread 01-02-2013, 17:56
AKA: Mr Tanguay
I think Jim was yanking my chain (also non-ferrous) for not being more specific.
Thanks for the source info though. We'll get our order in ASAP!
Unread 01-02-2013, 22:49
MrForbes's Avatar
AKA: Jim
It was a serious question, Dave, because the sprocket is aluminum and I thought they only worked on ferrous teeth.
Unread 01-02-2013, 18:15
electroken's Avatar
Electron Tamer
AKA: Ken Pontbriant
1. Digi-Key (hurry... only 22,000 left!)
2. The capacitor hiding in the epoxy is a 0.1uF 50V ceramic across power and ground.
3. We haven't tried reading sprocket teeth, but I would expect them to work well with steel sprockets and a small air gap.
Unread 14-02-2013, 14:10
philso philso is offline
FRC #2587
Electrotoken, am I right in thinking that the magnets in the hall effect sensor in the ATS667LSG detects the disturbances in the fields from the magnets mounted in the sensor package as the steel gears in the gearbox rotates through the field? Did you just connect it into one of the digital inputs on the Digital Sidecar? The datasheet does not seem to show any sort of calibration. Did you just stick it on, connect the wires and run?
Unread 14-02-2013, 15:03
electroken's Avatar
Electron Tamer
AKA: Ken Pontbriant
Your thinking is correct in that the magnet is buried in the sensor. I don't know if the 0.1uF cap I have between power and ground at the sensor end is strictly required, but it makes me feel better.
It really is as simple as wiring into the digital sidecar and counting pulses. We used two of these last year and will be using three this year.
Unread 02-02-2013, 04:23
carneeki carneeki is offline
AKA: Adam
FRC #3132 (Thunder Down Under), FRC#4774 (LAN Down Under)
carneeki is an unknown quantity at this point
Hi Katherine,
We (FRC #4774) are going to use the same sensor boards! Thanks for making them open for others
We (FRC #3132) *1 forgot to include the value of T1 on the schematic. It is a 2N2222 NPN transistor, a TO92 package. Part of me is wondering if we can make all components sit flat so the board could be laminated in a future revision?
BR,
Adam
*1 (Yes, I am a mentor for two teams)
FRC-3132 - Thunder Down Under - Mentor since 2011
FRC-4774 - LAN Down Under - Mentor since 2013
VK2JSI... Adam
Unread 02-02-2013, 18:13
Oldbikerider's Avatar
Oldbikerider Oldbikerider is offline
AKA: Graham
Oldbikerider will become famous soon enough
Hi Adam, we've just ordered magnets from a company in Sydney: http://www.magnet.com.au/neodymium_r...ts#discs_small
If I'd known that you were going to use the same sensors I'd have ordered enough for 4774 as well. We may have extras, so let us know if you need some.
Of course, as you know, DealExtreme also ship neo magnets to Australia.
Graham
FIRST® TEAM 3132
Thunder Down Under
Sydney, Australia
