Go to Post not national champ.....WORLD CHAMPION - Stephen Kowski [more]
Unread 24-01-2013, 17:30
ohhs4284 ohhs4284 is offline
FRC #4284
ohhs4284 is an unknown quantity at this point
Problem in eclipse deploying code.
We are having issues deploying our code in Eclipse. There is no issue when using the build function, but an error occurs when deploying the code. The error states
C:\eclipse\plugins\edu.wpi.first.javadev.sunsportf rcsdk_1.0.7.1\sunsportfrcsdk\ant\upgrade.xml:40: java.net.socketexception: Network is timed out: connect
We have tried many troubleshooting techniques but to no avail. Any help would be greatly appreciated.
Unread 24-01-2013, 23:35
Chiller Chiller is offline
AKA: Connor Christie
FRC #4095 (RoXI Robotics)
Chiller is on a distinguished road
Re: Problem in eclipse deploying code.
How are you programming in eclipse? Theres no updated plugin? are you sure its not netbeans? Did you set up your router and crio correctly? Did you set your comp ip? Did you configure the frc plugin for the correct ip? Did you disable all other network cards?
Unread 29-01-2013, 10:31
NotInControl NotInControl is offline
Controls Engineer
AKA: Kevin
FRC #2168 (Aluminum Falcons)
NotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond repute
The problem that you are having is because your computer can not connect to the cRIO.
I am not sure how you setup your ant build for 2013 but you need to provide it the IP address of your cRIO.
I hope you are not using the 2012 plug-ins, because they won't work!
It is possible to use eclipse for 2013 development. See my other thread on this topic and follow the video.
http://www.chiefdelphi.com/forums/sh...hlight=eclipse
there is a .sunspot.properties file in your user directory. In there should contain the IP address to the crIO, as well as the location to the new 2013 WPILIBJ library file.
Controls Engineer, Team 2168 - The Aluminum Falcons
[2016 Season] - World Championship Controls Award, District Controls Award, 3rd BlueBanner
-World Championship- #45 seed in Quals, World Championship Innovation in Controls Award - Curie
-NE Championship- #26 seed in Quals, winner(195,125,2168)
[2015 Season] - NE Championship Controls Award, 2nd Blue Banner
-NE Championship- #26 seed in Quals, NE Championship Innovation in Controls Award
-MA District Event- #17 seed in Quals, Winner(2168,3718,3146)
[2014 Season] - NE Championship Controls Award & Semi-finalists, District Controls Award, Creativity Award, & Finalists
-NE Championship- #36 seed in Quals, SemiFinalist(228,2168,3525), NE Championship Innovation in Controls Award
-RI District Event- #7 seed in Quals, Finalist(1519,2168,5163), Innovation in Controls Award
-Groton District Event- #9 seed in Quals, QuarterFinalist(2168, 125, 5112), Creativity Award
[2013 Season] - WPI Regional Winner - 1st Blue Banner
Unread 30-01-2013, 16:37
apples000's Avatar
apples000 apples000 is offline
apples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant future
If you don't have an important reason for developing with eclipse, I would recommend using netbeans. It has almost all of the same features, but its easier to get started with, and people will be able to help you more if you're using net beans.
Unread 01-02-2013, 09:43
java4first java4first is offline
(Java) Programming Mentor
AKA: Stu
FRC #0501 (Power Knights)
java4first is an unknown quantity at this point
I think you should work with what you are familiar with ... I personally think Eclipse is way better than Netbeans, and see no reason not to do it (Netbeans is not easier to get started with, and it uses way more resources than some of our old & tired laptops have). The FRC plugins aren't magic, and the YouTube video on the web is pretty straight forward on how to get going with Eclipse this year (we are currently running Eclipse on Windows, Linux and Macs for development).
From what you have, it sounds like you didn't define the remoteaddress property on the run Ant target with the IP address of the robot (we had the same problem until we watched the YouTube video). Although you can mess around with the properties files, you can also specify it on the command line arguments for your custom build command. If you can ping the robot successfully, then the deploy should work.
Unread 01-02-2013, 09:48
AKA: Stu
Again, assuming you can ping the robot successfully (or, as a better test, download and run a simple project using NetBeans) - the problem is likely to be the step at minute 20:00 in this YouTube video, which is what we used to get up and running.
http://www.youtube.com/watch?v=onGfI0zO4Oo
Unread 01-02-2013, 12:58
Controls Engineer
AKA: Kevin
Glad to see the video is helping
