Go to Post As engineers we should aspire to create, not destroy. If this is the case, why would we want to create machines with the sole purpose to destroy? - WakeZero [more]
Thread Tools Rating: Thread Rating: 22 votes, 5.00 average. Display Modes
Unread 01-02-2013, 10:30
UriF UriF is offline
FRC #2213
UriF is an unknown quantity at this point
Re: Gyro PID Programming
Thank you Jefferson, Ether. You have helped me understand this greatly.
Unread 01-02-2013, 11:19
Originally Posted by Jefferson View Post
So, get the input corrected to match the suggested range. This isn't just scaling or constraining, btw. You will need to add or subtract the extra turns if they are in there (fmod).
remainder(x,360) takes any angle and normalizes it to the range -180..+180. In other words, it finds the equivalent smallest-magnitude angle. fmod does not do this.
Once your angle is in the range -180..+180, you can simply divide it by 180 to put it in the range -1..+1 if you want.
If your C compiler does not have a remainder(x,y) function per per IEC 60559
as specified on Page 235 Section 7.12.10.2 of ISO/IEC 9899:TC3 ,
you can create your own as I showed in a previous post.
