Go to Post Who cares about the score? The score is just numbers on a board, the exciting part is watching the robots interact and seeing robots( and more importantly, people) do the impossible. - Herodotus [more]
Unread 01-02-2013, 12:12
Re: Setting and saving values on Dashboard
The attached image shows the palette that exposes the VI Server. The VI Server is a hierarchy of class oriented services to the LabVIEW editor itself and to the objects on panels.
To the left of the palette are the VI methods for getting and setting a control value by name.
To their right are property nodes that get or set the value via an object refnum. You get the refnum using other VI server icons, or you can use linked property nodes that are bound to a specific control.
The VI Server is super powerful, but not the simplest thing to figure out. You may find the examples helpful, and you may also decide that the locals are good enough for what you are doing and you don't need a more extensible solution like VI Server.
Greg McKaskle
