Go to Post make your robot so it's not a problem and it won't be a problem - pfreivald [more]
Unread 01-02-2013, 12:17
Nicolas BR's Avatar
Nicolas BR Nicolas BR is offline
FRC #1860
Nicolas BR is an unknown quantity at this point
Talking CEPHAS 1860 - 10 POINTS/30 POINTS CLIMB
This video shows only the climb of the first level, however for the other levels the mechanism is the same, let's make the climb of 30 points, we tested the concept, and proved that it really
http://www.youtube.com/watch?v=ajAWPyx8dCQ
Unread 01-02-2013, 13:46
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Re: CEPHAS 1860 - 10 POINTS/30 POINTS CLIMB
How do you tip in the right direction to climb another level if the actuation bar is higher than 30" and thus you can't be 'inside' the tower?
Unread 01-02-2013, 13:49
mikegrundvig mikegrundvig is offline
FRC #2410 (Metal Mustangs)
mikegrundvig is an unknown quantity at this point
I'd like to know this as well.
-Mike
Unread 01-02-2013, 13:57
Nicolas BR's Avatar
FRC #1860
Yes, but our mechanism was made to climb the outside of the pyramid, so we do not need nor want to enter the pyramid....
Unread 01-02-2013, 14:06
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
He meant the arm would not be angled to within the pyramid, thus your next "claw" would be grabbing air.
Academic Student (Forever)
Unread 01-02-2013, 14:18
Nicolas BR's Avatar
FRC #1860
Yes it would take the air, but the other two arms, will be articulated until they are parallel with the bars 60'' and 90''
Unread 01-02-2013, 14:23
CalTran's Avatar
Missouri S&T Senior
I assume you have an articulation method not affected by the pendulum motion of the robot?
Unread 01-02-2013, 14:30
sloteera's Avatar
sloteera sloteera is offline
AKA: Rafa
FRC #1860 (Cephatron)
sloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud of
we'll move away from the bars with an articuladed and angulated device (in order to keep the robot most parallel possible to the ground).
So two similar arms (some little differences) could be grab another bars.
Maybe we need to change the position of the robot's mass center, but we haven't sure yet.
Unread 01-02-2013, 14:31
Nicolas BR's Avatar
FRC #1860
yes, independently of the pendulum robot our method is not affected. We are centralizing all the weight is in the robot, so that the least possible angule ...
Unread 01-02-2013, 14:36
coldfusion1279 coldfusion1279 is offline
AKA: Mike
FRC #1279 (Cold Fusion)
coldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud of
Using the center of gravity to your advantage for a hang like this would be quite smart. Looks like you know at roughly what angle the robot comes to rest. At the very least, you are all set for 10 pts.
Cold Fusion's 10th Season
Unread 01-02-2013, 14:49
Sadly, this is quite far from being a 30 pt climber still. Your winch works great, and using bars to force the robot into the right plane for the next grab is a start, but you also have to have a second clamp hold you steady while you grab the next bar, rinse and repeat for the third bar. It's not nearly as simple as what I stated either, you have to overcome to offset the bumpers put on you as well.
-Mike
Unread 01-02-2013, 14:51
sloteera's Avatar
AKA: Rafa
-Mike
Sure, you right! We need to mount everything first. Then we can say that we have a 30 point's 'climber' robot.
Unread 01-02-2013, 22:50
Alex.q Alex.q is offline
FRC #2220 (Blue Twilight)
Alex.q is on a distinguished road
I dont think it is as complicated as everyone else is saying. They can take the same mechanism they have and duplicate it, then mount it so they can pivot it forward to engage the next bar.
Unread 01-02-2013, 22:56
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
What happens when the power to the field/robots is cut?
"A genius is just a talented person who does his homework" T. Edison
Unread 01-02-2013, 23:21
Johnbot's Avatar
Johnbot Johnbot is offline
Es Brokein!
AKA: John Westhoff
FRC #4791 (Pandroids)
Johnbot is just really niceJohnbot is just really niceJohnbot is just really niceJohnbot is just really niceJohnbot is just really nice
Well, considering they are just testing by wiring the motors directly to the battery, when power is cut their design will handle just like it did at the end of the video when the wires were removed from the battery: the robot stayed in place.
Anyways, this seems like an interesting way to go. If you have another hook off center, will the robot tip, or is the one hook enough to hold it without the robot falling off?
2011-2014 - FRC 2607 - Student
2012-2012 - FLL 2249 - Coach
2015- ???? - FRC 4791 - Mentor
