Go to Post You don't have enough money, you're under-staffed, you're not quite sure what the customer wants, requirements change, and they want it yesterday. - Kimmeh [more]
Unread 31-01-2013, 20:19
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
CRIO Slot 4 "Digital module 4 is not present."
We have reimaged the CRIO with the slots in 1,3 and 4 (1=analog,3=pneumatic,4=digital) and deployed code where the speed controllers are declared using
SpeedController s = new Talon(4,1);
The digital sidecar is powered and works when in slot 2. The digital sidecar is powered and works when in slot 2.
Output when deployed:
[cRIO] Digital module 4 is not present.
[cRIO] Uncaught exception in Thread.run():
[cRIO]     on thread testing.Test - main
[cRIO] edu.wpi.first.wpilibj.util.AllocationException: PWM channel 1 on module 4 is already allocated
[cRIO]     at edu.wpi.first.wpilibj.PWM.initPWM(PWM.java:116)
[cRIO]     at edu.wpi.first.wpilibj.PWM.<init>(PWM.java:135)
[cRIO]     at edu.wpi.first.wpilibj.SafePWM.<init>(SafePWM.java:43)
[cRIO]     at edu.wpi.first.wpilibj.Talon.<init>(Talon.java:59)
[cRIO]     at testing.Test.<init>(Test.java:26)
[cRIO]     in virtual method #11 of com.sun.squawk.Klass(bci=53)
[cRIO]     at com.sun.squawk.imp.MIDletMainWrapper.main(99)
[cRIO]     in virtual method #95 of com.sun.squawk.Klass(bci=25)
[cRIO]     at com.sun.squawk.Isolate.run(1506)
[cRIO]     at java.lang.Thread.run(231)
[cRIO]     in virtual method #47 of com.sun.squawk.VMThread(bci=42)
[cRIO]     in static method #3 of com.sun.squawk.VM(bci=6)
We made a new project with only creating objects and it still gave this error. I am 100% sure it does not instantialize the object more than once. Any ideas?
Full code of test:
public class Test extends IterativeRobot {
    private Joystick j = new Joystick(1);
    private SpeedController s1 = new Talon(4, 1),
            s2 = new Talon(4, 2),
            s3 = new Jaguar(4, 3),
            s4 = new Jaguar(4, 4),
            s5 = new Jaguar(4, 5),
            s6 = new Jaguar(4, 6);
     * This function is called periodically during operator control
    public void teleopPeriodic() {
        double speed = j.getRawAxis(3);
        SmartDashboard.putNumber("Speed", speed);
        s1.set(speed);
        s2.set(speed);
        s3.set(speed);
        s4.set(speed);
        s5.set(speed);
        s6.set(speed);
All opinions are my own.
Unread 31-01-2013, 20:21
AKA: Joel Gallant
Re: CRIO Slot 4 "Digital module 4 is not present."
Forgot to mention that CRIO is the 4 slot model. It is properly imaged with v47 of Java image.
Unread 31-01-2013, 20:26
Volunteer, WPILib Contributor
no team (Waiting for 2021)
The reason that is not working is that when you put a module in slot 4, the code sees that as module 2 of that type. So instead of declaring (4,1) declare (2,1) and it should work. Also there has to be a digital module in slot 2 because of the rules. This is so the RSL light has a place to connect to.
Team 4488 - Mentor 2013-2016
Unread 31-01-2013, 20:29
AKA: Joel Gallant
Thanks. Solved.
Unread 01-02-2013, 11:52
Secretspy97 Secretspy97 is offline
FRC #1126
Secretspy97 is an unknown quantity at this point
As of 2012, instead of declaring each slot number, you now have to only say if the module is in it primary position (1), or its secondary position (2).
WHAT TIME IS IT?
1126
Unread 01-02-2013, 13:01
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Originally Posted by joelg236 View Post
Thanks. Solved.
Please pay close attention to what the previous poster said about digital side car position.
In 2011, we thought we were able to put it in the secondary slot (we had some dimensional interferences with it in the first slot). At inspection, we found that you MUST have one in the first slot. Your robot may work fine other than the signal light, but you will not pass inspection if your inspector is on the ball.
Unread 01-02-2013, 13:03
AKA: Joel Gallant
We're aware of the rule. It is easier to do it in slot 4 for testing (cord to sidecar is really short). Thanks.
