Go to Post IF teams did NOT READ THE FIRST MANUAL AND Q&A SITE, it is not FIRST's fault, it is the TEAM'S fault - sburro [more]
Unread 02-01-2013, 01:58 PM
daneelshof's Avatar
daneelshof daneelshof is offline
Programming Mentor
FRC #1619 (Up-A-Creek Robotics)
daneelshof has a spectacular aura aboutdaneelshof has a spectacular aura about
pic: 1619 Sneak Peek (Aka, wheel bracket)
Unread 02-01-2013, 01:59 PM
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: pic: 1619 Sneak Peek (Aka, wheel bracket)
Are you using 8+" wheels? Or do you just want a ton of ground clearance?
Unread 02-01-2013, 02:38 PM
coldfusion1279 coldfusion1279 is offline
AKA: Mike
FRC #1279 (Cold Fusion)
coldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud of
Judging by how rounded those brackets are, I'd say they are designed to navigate their way around bars... I'm seeing a lot of fabricated items that have this shape. Very ambitious- good luck this season.
Cold Fusion's 10th Season
Unread 02-01-2013, 11:09 PM
camalex3999 camalex3999 is offline
AKA: Cameron Alexander
FRC #3999 (The Shadetree Mechanics)
camalex3999 is an unknown quantity at this point
Wow! Very nice.
We also made wheel brackets that drop our wheels (4" vex pro wheels) an inch below the chassis, but ours are much less pretty. We cut 3" sections of right angle aluminum and drilled the holes to fit on the chassis and for our axles.
Unread 02-02-2013, 03:40 PM
daneelshof's Avatar
Programming Mentor
We are using BRECOflex belts for the drive. They are work great and we've used them several seasons. We will be climbing the pyramid and these are needed for the clearance of the climbing mechanism.
