Go to Post I would say that you are not an engineer until you've both obtained the aforementioned peice of paper AND done something with your tumescent engineers forebrain. - phrontist [more]
  #46   Spotlight this post!
Unread 01-02-2013, 15:21
MisterG's Avatar
MisterG MisterG is offline
Think twice post once.
AKA: Alan Gilgenbach
FRC #2062 (C.O.R.E. - Community of Robotics Engineers)
Team Role: Team Spirit / Cheering
MisterG is a name known to allMisterG is a name known to allMisterG is a name known to allMisterG is a name known to allMisterG is a name known to allMisterG is a name known to all
Re: Best way to measure period between pulses? Counters and FPGA
Originally Posted by nightpool View Post
Doesn't that mean it wouldn't be able to tell if the wheel is actually stopped?
Oh, yeah. Basically it will continue returning some higher speed that represents the last valid transition even though the wheel may have stopped some time earlier.
So we probably need to decide some happy medium rotational velocity that we want to control and set the period accordingly.
-al g
Alan Gilgenbach
C.O.R.E 2062
  #47   Spotlight this post!
Unread 01-02-2013, 15:44
MisterG's Avatar
Originally Posted by sst.thad View Post
If you look at the code the only reason it has that function is to not have a divide by 0 error. In the get period function, it uses that bool in order to not make it divide by 0.
Note: the problem that we are dealing with is primarily due to the one pulse per revolution setup.
Agree that the stall feature is solving the zero divide problem but probably more importantly its dealing with the issue of period growing dramatically as rotational velocity approaches zero.
Take the following scenario: you decelerate very rapidly and your last transition happens at a time that is equivalent to 200 RPM. The wheel is stopped but the code continues to report 200 RPM. If the timeout (max period/min rate) is set for 10 RPM this will continue for 6 seconds.
Another interesting C++ fact that I never realized before (or once I knew but forgot):
For IEEE floats, division of a finite nonzero float by 0 is well-defined and results in +infinity (if the value was >zero) or -infinity (if the value was less than zero). The result of 0/0 is NaN. If you use integers, the behaviour is undefined.
Alan Gilgenbach
C.O.R.E 2062
  #48   Spotlight this post!
Unread 03-02-2013, 10:42
The IEEE defined behavior is the same for LV, and I presume Java.
Greg McKaskle
  #49   Spotlight this post!
Unread 07-02-2013, 23:29
matthewkennedy matthewkennedy is offline
FRC #1294 (Top Gun)
matthewkennedy is an unknown quantity at this point
It is pretty certain that is is going to be the same for C++/Java/LV as this behavior is typically determined by the FPU in the processor. I know that PPC conforms to the IEEE spec, and it properly handles x/0 for the three cases above.
-Matthew
"The future is already here—it's just not very evenly distributed"
-William Gibson
  #50   Spotlight this post!
Unread 08-02-2013, 07:18
I agree that PPC is IEEE 754 compliant, but some languages will have their own conventions, and since Java in interpreted, it would be pretty easy and efficient for them to have thrown an exception or taken some other action.
Greg McKaskle
