Go to Post Ok, so you are going to use a robot to hold all of those rivets together? - gblake [more]
Unread 01-02-2013, 16:57
BobbyVanNess's Avatar
BobbyVanNess BobbyVanNess is offline
AKA: Bobby Van Ness
FRC #0020 (The Rocketeers)
BobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of light
Re: Ultimate ascent options?
Keep in mind, you can only use the six alliance color discs when scoring in the pyramid. they are worth 5 points each. If you can score all of them successfully (requires 2 trips, because you can only handle 4), then the points value is equivalent to a third level climb. That being said, if you can quickly climb the first level (all you have to do is get the bot completely off the ground), then that gives you a 10 point bonus, which may be beneficial to do in the last few seconds.
2016 TVR Finalists, FLR Champions, Carver Sub-Division
2015 TVR Finalists, Carson Sub-Division Champions, IRI
2014 TVR Champions, FLR Champions, Archimedes Division, IRI
2013 WPI Regional Finalist, Connecticut Regional Champion, Archimedes Division, IRI
2013 Championship and IRI Talent Show winner
2013 - 2014 Driver: 82-43
Lead Strategy Mentor: 32-15
Unread 09-02-2013, 19:45
JesusC JesusC is offline
FRC #4633
JesusC is an unknown quantity at this point
Wait, so you are telling me that we can only shoot the six coloured Frisbee at the pyramid, and everything else at the wall, can you please tell me where this is in the rules, I didn't see this.
Unread 09-02-2013, 19:50
You can shoot the colored frisbees into any goal for points. However, they are worth the most in the pyramid goals (5 points as opposed to 3 points). White discs do not score points in the pyramid goals.
Let me rephrase the sentence that was giving you confusion: "Keep in mind, you can only use only the six alliance color discs when scoring in the pyramid." (Misplaced modifiers tend to lead to ambiguity--anybody in an English class, take note.)
Unread 09-02-2013, 19:59
FRC #4633
thank you, that definitely helps, otherwise, we would have wasted our time shooting white discs into the pyramid
Unread 09-02-2013, 20:29
jp1247's Avatar
jp1247 jp1247 is offline
No the cRio does not like aluminum!
FRC #1247 (ROK BOT)
jp1247 is an unknown quantity at this point
Why not climb, then proceed to shoot freebees? maximum points!
"No, you can't use the Kinect to do pelvic thrusts."
Unread 09-02-2013, 20:38
AKA: Bobby Van Ness
You mean shooting while hanging? You would only be able to take a maximum of 4 shots, unless you climb back down, making the whole climb pointless.
