Go to Post I found the best way to slice through pit crowds is to carry a clipboard and look like you know where you are going. People just seem to slide out of your way. :) - Ian Curtis [more]
Unread 01-02-2013, 14:12
Re: remainder function
Originally Posted by 1075guy View Post
OK, so do this instead:
output = (719 % 360 > 180) ? (-360 + (719 % 360)) : (719 % 360);
Fails when angle = -359. Doesn't work with floats.
Unread 01-02-2013, 14:16
Originally Posted by sur View Post
It looks like you need to define it using extern "C" for WindRiver to compile it correctly:
#include <cmath>
using namespace std;
extern "C" double remainder(double, double);
Would you mind running that and see if it produces the same output as this:
double myRemainder(double x, double y){
return x-y*floor(0.5+x/y);
Unread 01-02-2013, 15:12
Racer26 Racer26 is offline
What about:
double EthersRemainder( double x, double y ){
int wholenumber;
wholenumber = (int)(x/y);
double result;
result = (x - (wholenumber * y));
if(result > 0.5*y) {
result -= y;
return result;
Unread 01-02-2013, 15:41
What about:
EthersRemainder
That's not my remainder.
Did you compile and run it ? It doesn't work correctly.
I'm sure that there's a way, with enough conditional logic, to torture fmod() or % into into a remainder* function, but what I am really asking in this thread is
a) does the C++ compiler provided with FRC have the remainder* function, and
b) does it behave like this:
*This* is my remainder:
*per IEC 60559 as specified on Page 235 Section 7.12.10.2 of ISO/IEC 9899:TC3
Unread 01-02-2013, 17:23
If you have a function that works, then use it?
I don't understand your qualm?
I have not ever encountered a programming scenario where modulus division didn't solve my desire for a remainder, so I'm a bit lost.
If there doesn't exist an operator that does what you want, then you need to either a) fabricate a solution from the operators you have access to, or b) find a library that does that for you.
Unread 01-02-2013, 18:16
I do use it. But I don't want to be telling other people to use my custom function if there's already a perfectly good remainder function provided with FRC C++. I don't have access to a working C++ installation, otherwise I would test it myself. I am seeking help from knowledgeable C++ users on this forum.
Honestly, that's because I don't have a qualm. I am perfectly calm.
I have encounted at least one such scenario, and that's why I posted this thread.
For example, the IEC60559 remainder function can take any angle and normalize it to the range -180..+180 with a single C instruction:
normalizedAngle = remainder(angle,360);
I'd like to know if the remainder function is supported in FRC C++ so I can recommend it to students who are trying to do this type of conversion.
Neither the fmod() function nor the % operator can replicate the functionality of the remainder() function without using a bunch of conditional logic
If there are any Java programmers following this thread, Java appears to have the IEC 60559 remainder function; in Java it is called IEEERemainder. See attachments. If someone would be willing to test that (compare it to the implementation I posted ealier in this thread) I'd be grateful.
qualm
/kwä(l)m/
Noun
1) An uneasy feeling of doubt, worry, or fear; a misgiving.
2) A momentary faint or sick feeling.
Synonyms
nausea - queasiness
ID:	13749  Click image for larger version
Unread 01-02-2013, 19:06
omalleyj omalleyj is offline
AKA: Jim O'Malley
FRC #1279 (Cold Fusion)
omalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to behold
In a Java SE project this
        double result;
        double x[] = {179, 180, 181, 359, 721, -1, -179, -180, -359, -361, -721};
        for (int i = 0; i < x.length; i++){
            result = Math.IEEEremainder(x[i],360.0);
            System.out.println("x: " + x[i] + " rem y: 360 result: " + result);
yields this:
x: 179.0 rem y: 360 result: 179.0
x: 180.0 rem y: 360 result: 180.0
x: 181.0 rem y: 360 result: -179.0
x: 359.0 rem y: 360 result: -1.0
x: 721.0 rem y: 360 result: 1.0
x: -1.0 rem y: 360 result: -1.0
x: -179.0 rem y: 360 result: -179.0
x: -180.0 rem y: 360 result: -180.0
x: -359.0 rem y: 360 result: 1.0
x: -361.0 rem y: 360 result: -1.0
x: -721.0 rem y: 360 result: -1.0
which I believe is what you are looking for.
However I cannot use IEEERemainder() in an FRC project they have compiled the jar without it apparently.
Last edited by omalleyj : 01-02-2013 at 19:16. Reason: still can't spell after all these years
Unread 01-02-2013, 20:23
[snip]
yields this:
[snip]
Excellent. Thank you! I'd give you some more reps, but it won't let me
Not being a Java user, I'm not sure what that means. Is there a way to re-compile to include it, or is that a major undertaking?
Are there any C++ gurus out there who can look into the same question for C++ ?
Unread 01-02-2013, 20:34
That's not entirely true. FRC uses the Squawk JVM, which is based on Java ME. Java ME does not require IEEERemainder(), which is why it isn't in java.lang.Math. However, Squawk does implement some features from Java SE, and puts them in other packages. In this case, IEEERemainder is in the com.sun.squawk.util.MathUtils package.
Unread 01-02-2013, 20:39
AKA: Jim O'Malley
Thanks!
Is there a cross reference of where SE stuff that's been moved can be found?
Unread 01-02-2013, 20:49
Joe, you never cease to amaze me
Unread 01-02-2013, 21:54
Here's the result from the robot
        double result;
            result = MathUtils.IEEEremainder(x[i],360.0);
[cRIO] x: 179.0 rem y: 360 result: 179.0
[cRIO] x: 180.0 rem y: 360 result: 180.0
[cRIO] x: 181.0 rem y: 360 result: -179.0
[cRIO] x: 359.0 rem y: 360 result: -1.0
[cRIO] x: 721.0 rem y: 360 result: 1.0
[cRIO] x: -1.0 rem y: 360 result: -1.0
[cRIO] x: -179.0 rem y: 360 result: -179.0
[cRIO] x: -180.0 rem y: 360 result: -180.0
[cRIO] x: -359.0 rem y: 360 result: 1.0
[cRIO] x: -361.0 rem y: 360 result: -1.0
[cRIO] x: -721.0 rem y: 360 result: -1.0
Unread 01-02-2013, 21:55
Thanks!
It's all in the javadocs, but I'm not aware of an easy cross reference.
Unread 01-02-2013, 22:17
Bingo! They match.
Unread 02-02-2013, 02:16
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
From my installation, a grep through the headers folder shows no remainder functions. It's possible I'm missing something, but it looks like it doesn't exist at all in the vxWorks API.
As for the extern "C" option, yes that will make it compile, however the function will most likely not be resolved by the linker, which will cause problems when you try to run it. Wind River's system is designed to not complain about missing symbols until the cRIO's kernel tries to load the program. I'll check if this is the case tomorrow.
EDIT: actually, drem() does exist, and is defined to be the same as remainder() (see the glibc manual). However, the definition for it is in <private/trigP.h>, which isn't meant for inclusion by user programs. There don't seem to be any public headers which include it either.
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
