Go to Post I think FIRST is a big trap. They lure you in with these cool competitions and shiny robots and along the way they trick you into learning something :) - =Martin=Taylor= [more]
Unread 01-02-2013, 20:37
iambujo iambujo is offline
FRC #2729 (Storm)
iambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to all
Blue vs Yellow crimp connectors
I have a question, maybe one I will regret asking.
The yellow crimp connectors have #10-#12 marked on them, and the blue have #14-#16 marked on them. Is this based solely on the size of the hole for accommodating the wire, or is it based on current ratings. I have looked up several on the web, and it seems to be related to size, since I didn't see specs for current rating.
So, if using #12 wire from PDB motor controller, is it 'legal' to use blue connectors if they fit and crimp tight? Or can that get flagged as illegal during inspection?
Thanks
