Go to Post If you don't manage weight from the beginning, weight will manage you at the end. - charrisTTI [more]
Unread 01-02-2013, 20:49
Re: remainder function
Originally Posted by Joe Ross View Post
That's not entirely true. FRC uses the Squawk JVM, which is based on Java ME. Java ME does not require IEEERemainder(), which is why it isn't in java.lang.Math. However, Squawk does implement some features from Java SE, and puts them in other packages. In this case, IEEERemainder is in the com.sun.squawk.util.MathUtils package.
Joe, you never cease to amaze me
