Go to Post Physical items will be lost along the way eventually but memories will never be forgotten. - Connor McBride [more]
Unread 31-01-2013, 20:38
Lemons's Avatar
Lemons Lemons is offline
AKA: Gooby
FRC #2383 (Ninjineers)
Lemons is an unknown quantity at this point
US Digital Encoder Distance/sec to Rpm
Ok so this is the first year we have really decided to implement digital encoders on motors. We hooked them up fine and using the example code in LabVIEW were able to get readings. The only question we have is what unit (distance/second) is the encoder reading in and is it possible to change that unit (distance/second) to an RPM reading if its not already set as such? We are using US Digital E4P Quadrature encoders. Thanks
Unread 31-01-2013, 22:21
Team3266Spencer's Avatar
Team3266Spencer Team3266Spencer is offline
Team Captain and Lead Programmer
AKA: Spencer Lanman
FRC #3266 (Robots-R-US)
Team3266Spencer is an unknown quantity at this point
Re: US Digital Encoder Distance/sec to Rpm
Most encoders, and I would assume yours, record the time between two "sprockets" inside the encoder. There are 360 of these bumps inside the encoder so a raw encoder reading will be in degrees. I don't program in LabView, but assuming it's the same speed settings, given with time in seconds, and you want RPMs, you would have to divide by 360 and multiply by 60, or just divide by 6. If you want to calculate distance travelled by a drivetrain lets say, you would need values such as the gear ratios used, and the diameter of the tires, etc.
2012: Buckeye Regional, Queen City Regional, Human Player
2013: Queen City Regional, Buckeye Regional, Crossroads Regional
Shooter Operator
2014: Crossroads Regional, Queen City Regional
Catapult Operator
2015: Georgia Southern Classic Regional (Winner), Queen City Regional
Chainsaw Operator
Want to talk? TeamSpeak: team3266.noip.me
Unread 01-02-2013, 18:45
blackflame2996's Avatar
blackflame2996 blackflame2996 is offline
Alumni
AKA: David Donahue
FRC #2996 (Cougars Gone Wired)
blackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to all
Actually, the number of pulses per revolution varies. On the casing of the E4P, 3 digits in the number are the pulses/revolution, ranging from 100 to 360. The bore will also be on there, so don't let that throw you off. for example:
http://ivan.blogs.chimerical.com.au/..._36_resize.jpg
The Pulses/Revolution on this encoder is 300, and the Bore is .157 inches.
2009 Regional Winners
2011 Regional Chairman's Award
2012 Regional Winners
2013 Regional Chairman's Award
Unread 01-02-2013, 20:09
That number is Cycles Per Revolution, not Pulses Per Revolution. Those terms mean different things.
Unread 01-02-2013, 23:16
Alumni
AKA: David Donahue
You are correct. My bad.
