Go to Post Injuries can come out of no where. I know this is only a robotics competition but the injury doesnt care where or what you are doing. - nightrenegade00 [more]
Unread 01-02-2013, 21:08
akash992391 akash992391 is offline
AKA: Akash
FRC #4684
akash992391 is on a distinguished road
Shooter PROBLEM
HIIII
i dont know wats going in on with our shooter.We tried everything and we show some video and see other shooter but we cant really figure it out wats wrong with our shooter its shoots half way with two pneumatic tires... and we have really big problem we spent about 5 hours on it and dont know wats wrong...can u please help us...
Unread 01-02-2013, 21:10
nikeairmancurry's Avatar
nikeairmancurry nikeairmancurry is offline
FF - TeamSuperPowerMatic
AKA: Nicholas
FRC #0313
nikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond repute
Re: Shooter PROBLEM
You might want to describe more of what the issue your having is. Also it's helpful to know what type of motor is driving your shooter along with the possible gear ratio.
Team Member- 326 2006-2009
Team Mentor- 326 2010-2013
Team Mentor- 313/5220 2014-??
Unread 01-02-2013, 21:15
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Re: Shooter PROBLEM
Pictures and youtube videos of the problem can help.
Also measure the distance between the wheel and the rail that guides the frisbee. Have you adjusted it to be less than the frisbee diameter?
Unread 01-02-2013, 21:34
AKA: Akash
FRC #4684
Re: Shooter PROBLEM
our CIM motoris connected to the robot with a 8mm hub 8" pneumatic wheels
and idk y cant i upload a video for u
Unread 01-02-2013, 23:39
AKA: Nicholas
FRC #0313
Re: Shooter PROBLEM
Put the video on youtube and post the link.
Unread 01-02-2013, 23:42
BobbyVanNess's Avatar
BobbyVanNess BobbyVanNess is offline
AKA: Bobby Van Ness
FRC #0020 (The Rocketeers)
BobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of light
Re: Shooter PROBLEM
If you could post a picture of the shooter, we might be able to help. A video could help a lot more. What do you mean when you say "half way"? There are a lot of small adjustments you can make that have a large impact in a shooters performance. One main one is to increase the compression between the disc and the wheel(s). Second, make sure your shooter wheel RPMs aren't too high (ie. directly powered to the battery). The problem with this is that the wheels are moving too fast to connect with the disc. Try slowing them down. However, as said before, it's very difficult to diagnose a problem with a lack of details.
2016 TVR Finalists, FLR Champions, Carver Sub-Division
2015 TVR Finalists, Carson Sub-Division Champions, IRI
2014 TVR Champions, FLR Champions, Archimedes Division, IRI
2013 WPI Regional Finalist, Connecticut Regional Champion, Archimedes Division, IRI
2013 Championship and IRI Talent Show winner
2013 - 2014 Driver: 82-43
Lead Strategy Mentor: 32-15
Unread 02-02-2013, 00:23
lcoreyl's Avatar
lcoreyl lcoreyl is offline
WittyTitleGen can't link to library
AKA: Milner
lcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud of
Re: Shooter PROBLEM
In a more general sense, whenever you are prototyping you want to do the following:
1) what is the performance you are looking for? (i.e. what criteria do you have for "success")
example: the frisbee goes 30 ft horizontal and lands in the same spot every time +/- half a frisbee length (hint: the second example criterion is very important)
2) list all the variables you can think of that should have an effect on your performance goals
example: wheel speed, wheel size, wheel tread, etc...(hint: the list is much longer than this)
3) make a prototype and test its performance vs. your goals
4) change ONE variable, and test again (sometimes it might not be worth the time/effort to only change one, but do your best)
