Go to Post We are not the families of competiting robot teams, but we are a family of Gracious and Professionalism, because we know it better than anyone in the world. - wsansewjs [more]
Unread 02-02-2013, 01:28
adampaskowitz adampaskowitz is offline
FRC #4345
adampaskowitz is an unknown quantity at this point
Compressor & tank with one port each?
Every diagram I can find showing how to set up a pneumatic system has compressors and tanks with two ports. One port on the compressor, for example, goes to the pressure relief valve, and the other feeds into the system.
I have last year's KOP compressor and tank, which each have one port. So how do I connect the pressure relief valve , and the pressure switch? Do I just attach a tee to the compressor with the pressure relief valve on one of the branches? Do I then need a 4-way fitting on the tank to include an inlet, outlet, and pressure switch?
