Go to Post Honestly, no one at a FIRST competition is gonna judge you. Chances are, there are least 20 people dorkier than you. - JohnnyB [more]
Unread 02-02-2013, 01:32
dudefise dudefise is offline
FRC #2637 (Panthers)
dudefise is an unknown quantity at this point
Re: Compressor & tank with one port each?
Originally Posted by adampaskowitz View Post
Every diagram I can find showing how to set up a pneumatic system has compressors and tanks with two ports. One port on the compressor, for example, goes to the pressure relief valve, and the other feeds into the system.
I have last year's KOP compressor and tank, which each have one port. So how do I connect the pressure relief valve , and the pressure switch? Do I just attach a tee to the compressor with the pressure relief valve on one of the branches? Do I then need a 4-way fitting on the tank to include an inlet, outlet, and pressure switch?
Yes. You will need to put a tee (or perhaps more conveniently a "y" connector depending on space) at the compressor for the relief valve. In addition, you will need to add branches for the manual release valve, switch, tank and regulator input on the high-pressure side, probably with the tees you were talking about. We usually use three tee's to do this, putting the switch in line with either the tank or manual release.
2010 VRC 2453B - Team Captain
2011 FRC 2637 - Electrical - Las Vegas Regional Semifinalists with 1726 and 166
2012 FRC 2637 - Electronics Captain - Las Vegas Regional Semifinalists with 1661 and 2984
2013 FRC 2637 - Build Captain - Inland Empire Quarterfinalists with 3925 and 207
2014 FRC 2637 - College Mentor - Central Valley Quarterfinalists with 2085 and 5136 / LA Regional Semifinalists with 696 and 5102
2015 FRC 2637 - Lazy Schmuck - Couch Sitting Quarterfinalist
2016 FRC 2637 - College Mentor - SD Regional Finalist with 1572 and 2443, Excellence in Engineering, Wildcard
