Go to Post But here's the beautiful thing about FIRST: you are supposed to make mistakes. - RunawayEngineer [more]
Unread 02-02-2013, 01:23
omsahmad's Avatar
omsahmad omsahmad is offline
FRC #1595 (Dragons)
omsahmad is just really niceomsahmad is just really niceomsahmad is just really niceomsahmad is just really niceomsahmad is just really nice
How to cut image out of Sheet metal
Hello,
Our team wants to cut our team number and other images out of our sheet metal robot. We created them in illustrator, but don't know how to place them in a sketch such that they can be cut out. I have been playing with the "image" button, but can't seem to figure it out. Thanks for the help.
Unread 02-02-2013, 01:33
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
Re: How to cut image out of Sheet metal
Originally Posted by omsahmad View Post
Hello,
The way I usually do it is to insert image files in as objects and then trace them. That's in tools-> sketch tools ->sketch picture in solidworks ( I dont know about inventor). There might also be a way to insert vector images., but I dont have a clue there.
Unread 02-02-2013, 01:37
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
Not really sure how you're doing it in but in Solidworks you can use the text tool to make a font version of your team number and extrude cut it.
FTC Teams 5257, 6568 & FRC Team 3992
2014 FTC WORLD CHAMPIONS
14 Trophies in 3 Years
Unread 02-02-2013, 02:38
Garrett.d.w's Avatar
Garrett.d.w Garrett.d.w is offline
Build Lead
FRC #2733 (The Pigmice)
Garrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to behold
In inventor 2013 there is an option to insert an image in sketch mode. Here is a screen cap.
http://i.imgur.com/37DJXWX.png
Edit: Facepalm, you are already doing this.
For the team number you can do it using the text function in Inventor.
For an image, you can have a program export a series of X, Y values that inventor can then import from a spreadsheet. I have done this one other time, but I don't remember how. It's just a thought to try out.
Good luck
"A mind once stretched by a thought will never regain it's original dimensions."
Optimists think the glass is half full.
Pessimists think the glass is half empty.
Engineers realize it's twice as big as it needs to be.
Last edited by Garrett.d.w : 02-02-2013 at 02:47. Reason: Not a helpful answer to OP's question
Unread 02-02-2013, 22:59
omsahmad's Avatar
FRC #1595 (Dragons)
Interesting, remember the program you used by any chance?
Unread 02-02-2013, 23:01
omsahmad's Avatar
FRC #1595 (Dragons)
So you are actually re-drawing the image again in solidworks? This seems a little tedious, but not too bad.
Unread 02-02-2013, 23:25
If you dont have a vector image and you're just pulling a jpeg to cut out, you never really drew it the first time
Unread 03-02-2013, 02:53
Build Lead
Ok, Found out how to do it with inkscape.
here is a thread on a relevant forum:
http://www.inkscapeforum.com/viewtopic.php?f=5&t=8826
On this thread it recommends an extension for inkscape that will export your .svg file to a series of x,y data points.
To get this to work with a .jpeg, embed the .jpeg into an open inkscape document and then trace it. Save this traced image as an .svg. Reopen in inkscape and run the script, a popup will appear with the x,y coordinates which you then copy into an excel file. Save that and then import it using the function in inventor. If everything goes right, then you will get your image in the sketch.
I tried it with a very simple image and it seemed to work.
edit:The process took me about ten minutes including installing the extension. I could have drawn a simple image in a sketch in that time. It's cool, but evaluate the amount of effort that you will putting into this process. Also, as a side note, I hope that your computer has a lot of RAM, tracing a complex .jpeg eats gigs of RAM for breakfast.
Good luck
Unread 03-02-2013, 19:15
Dr. Shocker's Avatar
Dr. Shocker Dr. Shocker is offline
Alumn
FRC #1126 (SparX)
Dr. Shocker is on a distinguished road
If the trick with inkscape works, inkscape already has a built in automatic tracer if the image is a jpg or some other raster format. However, considering they made the drawing in illustrator, I would think they already have it in a vector format. There may be a similar tool in illustrator, but since inkscape's free they may be able to simply open up the file they already have in inkscape.
