Go to Post Build tough and come to play. - JaneYoung [more]
Unread 30-01-2013, 17:10
nheft nheft is offline
FTC #0533 (Psichotics)
nheft is a jewel in the roughnheft is a jewel in the roughnheft is a jewel in the roughnheft is a jewel in the rough
mating 5V connector for D-link
I'd like to wire the +5V to the D-link radio without chopping the cable off of the power cube that shipped with the radio. Does anyone know the right dimensions for the mating connector?
Unread 30-01-2013, 17:16
kjohnson's Avatar
kjohnson kjohnson is offline
Insert Clever Title Here
AKA: Kyle J.
FRC #1610 (BOT)
kjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond repute
Re: mating 5V connector for D-link
http://www.andymark.com/product-p/am-2298.htm
Unread 31-01-2013, 17:22
Thank you
Unread 31-01-2013, 17:45
ericbanker ericbanker is offline
FRC #1208 (The Metool Brigade)
Team Role: Electrical
ericbanker is an unknown quantity at this point
According to the Robot Power Distribution Diagram found here, the d- link should be powered by the 12v to 5v convertor. The 5v on the PDB is for the camera.
Last edited by ericbanker : 31-01-2013 at 17:47. Reason: actual name of link is Robot Power Distribution Diagram, not spec sheet for power distribution.
Unread 01-02-2013, 09:58
bbuncher12 bbuncher12 is offline
FRC #0540 (Talon 540)
bbuncher12 is an unknown quantity at this point
ericbanker is correct, the D-link should be powered by the 12V-5V converter that is supplied in the KOP. The converter should be wired into the small 12V connection near the cRIO power and 12V LED. The camera should go to the 5V port in the same area
Unread 02-02-2013, 03:56
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
Originally Posted by nukemknight View Post
AndyMark is out of stock. Radio Shack carries the connector: http://tinyurl.com/c4ku48t
or MCM Electronics: http://tinyurl.com/cwoacnq
or a cable at Altex: http://tinyurl.com/cg8as8p
Not that hard to find
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2016 Robot Inspector - Fingerlakes, Pittsburgh
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship - Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
Unread 02-02-2013, 10:18
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
I believe what he's asking is where to buy the plug that plugs into the radio because they don't want to cut the power brick apart.
2015 GKC Engineering Inspiration
2015 Colorado Winners
