Go to Post Having the ability, opportunity, and inclination to do manual labor makes you a better engineer. - MrForbes [more]
Unread 02-02-2013, 11:41
Connor1868 Connor1868 is offline
FRC #4143
Connor1868 is an unknown quantity at this point
How to toggle a relay with one button?
I need to turn a relay on and off your one button on the joystick. Much like a toggle button. Could some one give me some sample code?
Unread 02-02-2013, 11:53
Re: How to toggle a relay with one button?
Here's a generic button toggle example:
Put one Relay set in the inside True case, the opposite set in the inside False case.
Unread 02-02-2013, 11:58
FRC #4143
What are the green arrows?
Unread 02-02-2013, 12:09
The green arrow is found on the Programming -> Structures palette.
It's called a Feedback node, and what it does for you is remember the previous value, so the current value can be compared to the previous value.
So for the button press the value can be thought of as 0 (false) or 1 (true).
That first peculiar little combination is checking to see of the button is going from off (the previous value) to on (the current value), so it's only true the very first time you press the button and won't be true again until the button is release and pressed again.
To change the arrow direction once you put it on your block diagram, right-click and choose Change direction.
Unread 02-02-2013, 12:19
FRC #4143
How does the arrow become green? I found the arrow, but it is black.
Unread 02-02-2013, 12:22
It changes color based on the data type that then gets wired to it.
It's green in the example because a boolean wire got connected to it.
So it'll turn green when you wire the button output to it.
If you wired an integer to it, then it would turn blue.
A floating point number would make it orange instead.
Unread 02-02-2013, 12:25
FRC #4143
Thank you very much! It worked
Unread 02-02-2013, 12:33
FRC #4143
What about false in the outer case structure of?
Unread 02-02-2013, 12:38
The outer false case avoids doing anything at all.
That's when the button hasn't been pushed again.
The wire just gets passed from the input tunnel right to the output tunnel.
Unread 02-02-2013, 15:29
bvisness's Avatar
bvisness bvisness is offline
Programming Mentor, Former Driver
bvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of light
One of our veteran team members wrote a very simple and effective Toggle vi, which I've attached. Just feed the button signal into the input, then use the output with a select block or case structure to select your relay state.
Unread 29-06-2013, 16:04
bvisness's Avatar
I was asked to provide a screenshot of what our team's Toggle VI looks like, so here's how it works!
Name:	Screen Shot 2013-06-29 at 2.57.49 PM.png
Unread 29-06-2013, 23:21
Aren Siekmeier's Avatar
on walkabout
Note: Remember that this VI would have to be set to Reentrant Execution (under VI Properties>Execution) in order to have a separate saved state at the feedback nodes for each instance of the VI. Otherwise it will not work properly at all (rising edge detection fails and all outputs will be locked together...).
Unread 02-07-2013, 13:27
Racer26 Racer26 is offline
Ugh. The LabVIEW Developer in me can't stand feedback nodes. They make everything so much harder to understand.
Unread 02-07-2013, 15:47
Interesting. It's one of the symbols that seems second nature to me. Perhaps because of many years working with digital controls systems. It's just Z-1.
Unread 02-07-2013, 16:18
I understand them, but they break left to right data flow, which is considered a no-no in most of the LabVIEW world.
I prefer to use shift registers and while loops.
