Go to Post I trust my life to a 3650 pound rolling chunk of metal every day that, if some silicon failed in just the right (wrong?) way, would splat me pretty quickly, but I have faith in engineering. On the other hand, it doesn't turn me upside down. - DonRotolo [more]
Unread 02-02-2013, 08:52
jibicax jibicax is offline
AKA: Adina Paddy
FRC #3680 (Elemental Dragons)
jibicax is an unknown quantity at this point
Encoders and Motors
My team wants a robot that you press a button and a "ramp" moves so many degrees up or down. So, like a limit switch but without the absolute endpoints. I know an encoder can do that, but I never worked an Encoder before. I went through the LabVIEW examples till I created the vi below (all the proper open boxes are there). Which starts the motor, but it doesn't stop. Basically, I'm asking how to make an encoder control a motors set output.
PHP Code:
[ATTACH]13753[/ATTACH
Unread 02-02-2013, 15:55
bvisness's Avatar
bvisness bvisness is offline
Programming Mentor, Former Driver
bvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of light
Re: Encoders and Motors
Your problem is probably that the encoder does not measure in degrees. An encoder measures ticks per second, which is more suitable for measuring speed and distance than measuring angles.
I think your main problem, though, is that you're getting your current angle by dividing your Distance reading by 360 and taking the remainder. The Distance output will probably read something like inches or feet, depending on how you configured the encoder in Begin.vi. I would just experiment with different positions and find a more appropriate setpoint and process variable.
Or, if you really want to work with angles, you could try mounting a gyro sideways on your ramp. I don't think that's your best option, though.
Unread 02-02-2013, 16:55
I'd look at using a potentiometer for this kind of task.
Unread 02-02-2013, 17:46
Originally Posted by bvisness View Post
Your problem is probably that the encoder does not measure in degrees... An encoder measures ticks per second, which is more suitable for measuring speed and distance than measuring angles..
What an encoder "measures" depends on how its output signal is decoded. It can measure either angular position or angular speed. These can be converted into distance or linear speed.
http://en.wikipedia.org/wiki/Rotary_encoder
A gyro is a poor choice for measuring the angle of an adjustable ram.
Unread 02-02-2013, 17:51
bvisness's Avatar
Ah, you're right. Thanks for correcting me. If you could get an encoder properly configured (which is something that I always have trouble with) that would almost certainly be your best option.
Unread 02-02-2013, 17:55
I think a potentiometer would be a good, perhaps even better, option for this application (low speed, limited rotation), as Mark suggested.
