Go to Post A Mentor is.. A person you can talk to anything about and trust them to not throw it back in your face in any way shape or form and who will help you as much as they can to deal with the problems and situations in life... - Elgin Clock [more]
Unread 02-02-2013, 16:09
bvisness's Avatar
bvisness bvisness is offline
Programming Mentor, Former Driver
bvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of light
Re: Move Robot a set angle
I'd recommend the gyro as well. We found the provided gyro sensors to be very responsive and accurate. Easy to program too!
Using a gyro, it would be pretty easy to set up a PID loop like in the attached image.
Unread 02-02-2013, 18:05
Unless the 2013 LabVIEW PID now has support for "continuous" process variables (2011 didn't), your diagram won't work.
Unread 02-02-2013, 18:11
bvisness's Avatar
What do you mean by "continuous" process variables? This should get the current gyro heading every time the loop runs and compare that to the setpoint. (And this is just a 2-minute example anyhow...)
Unread 02-02-2013, 18:16
What do you think that PID in your diagram will do if the gyro is reading 359 degrees and your driver is commanding zero degrees ?
Unread 02-02-2013, 18:22
bvisness's Avatar
Ah, I see what you mean. I didn't say this was a perfect example, I just wanted to quickly demonstrate how one could zero in on an angle using a gyro and PID.
Unread 02-02-2013, 18:24
If you had to make this work, how would you go about fixing this problem?
Unread 02-02-2013, 18:32
bvisness's Avatar
Well, for the thread-starter's situation, I would initialize the setpoint as current heading + desired change. Then it wouldn't matter if the variable was continuous or not. (Assuming I'm remembering correctly that the gyro heading does not reset to 0 when it makes a full rotation.)
On the other hand, if I wanted to turn the robot to an absolute heading, I would probably...you know what, I'm not sure. All my ideas thus far would eliminate the problem of whirling in circles when going from, say, 2520 degrees to 45. But all my ideas would not fix the problem of going from 359 to 0.
Unread 02-02-2013, 19:05
thephpdev's Avatar
thephpdev thephpdev is offline
AKA: Josh Larson
FRC #2502 (Talon Robotics)
thephpdev is an unknown quantity at this point
You could use a PID loop with the x-offset in pixels as the input of the image, and have the output move the wheels.
Unread 02-02-2013, 19:26
How fast can your vision processing compute that image pixel offset ?
Unread 03-02-2013, 09:53
Circular coordinate systems have many values that encode the same angle.
Mod or Quotient and Remainder will collapse them into those represented in a single circle. As you noted, there are still two useful solutions to your 359 move to 0. You can move 359 degrees one direction or 1 degree the other.
You usually want to select the movement with the smaller absolute value. So you need mod, and you need to consider both the positive movement and negative movement. For crab systems or turrets, there is usually a further restriction that may invalidate one of the solutions -- cables only stretch and twist by so much.
I'd highly recommend you develop your input filter as a separate VI and test it for the full range of values it is to deal with. Often it is useful to plot the output versus input and sweep across the range of values at some resolution.
Greg McKaskle
Unread 03-02-2013, 16:31
bvisness's Avatar
Thanks for the advice! Granted, I'm not the one who started the thread, but I hope the info is useful to people who are attempting to do this.
Unread 03-02-2013, 18:16
bvisness's Avatar
Well, compwiztobe saves the day again with this awesome VI. I worked with him to get this written up; it takes a "continuous" gyro input and computes the appropriate setpoint to use in a PID loop. I've attached the VI and an example image.
Unread 03-02-2013, 23:33
Please post a PNG or GIF screenshot of the vi, for those of us who don't have LabVIEW installed (yet). Thanks.
Unread 03-02-2013, 23:41
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
To add to Ether's recommendation.
I was teaching how to use encoders and applying geometry and trigonometry. One of the tasks I had them figure out is to make the robot turn a certain angle using left and right encoders.
They were successful, but due to the slip-n-slide nature of your drive train, it really is by chance (aka lottery and moon phase). It was within about 10˚ of where it should have been.
Of course, a better solution (as also mentioned) would be to use the included gyro. It's easy to wire (have a spare PWM Cable?), easy to program (They have an example on how to use it), and easy to use (output is already in degrees).
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 04-02-2013, 05:38
sloteera's Avatar
sloteera sloteera is offline
AKA: Rafa
FRC #1860 (Cephatron)
sloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud of
It's a skid-steer vehicle, so it depends on the phase of the moon and yesterday's lottery numbers.
But seriously, you could use a gyro (as the previous poster suggested), or you could do some simple experiments and measure how much vehicle rotation you get vs how much the wheels turned. Do that under various conditions (like turning speed) and either fit a model to the data or prepare a lookup table. Make sure you use the same carpet as competition when running these tests, and with the competition weight.
You right Ether, I need to agree with you.
I've got little confused before. Now I understood why what I proposed wouldn't work.
Sorry.
