Go to Post FIRST: The hardest thing you'll ever love to do. - Stephen Kowski [more]
Unread 02-02-2013, 19:26
ctccromer's Avatar
ctccromer ctccromer is offline
Animus
AKA: Tucker Campbell
FRC #3753 (Bulah Bots)
ctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to all
Controller inputs resetting?
Today our buttons and axes randomly changed themselves for the SECOND TIME. Long story short, we had placed the whole electrical system and motors and everything on the robot temporarily. Today was our day to take it all off and put it back on (in somewhat different laces), but permanently this time.
After this, almost everything on the controller (logitech controller) simply made the robot turn left... I redeployed the SAME CODE that *should* have been on the cRIO and most of it works the same as it did. the X button (button 3) is still a little messy, but it could be that our window motor isnt powered correctly. There's still a lot we need to look into. Today was a frustrating day for the whole team..
But anyways.. has anyone had issues with a logitech controller (seemingly) randomly reassigning button maps??
Team 3753 BulahBots
Unread 02-02-2013, 19:28
bvisness's Avatar
bvisness bvisness is offline
Programming Mentor, Former Driver
bvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of light
Re: Controller inputs resetting?
The first thing that comes to mind is that you have the joysticks configured in the wrong order. Check the Setup tab of your driver station to make sure. Besides that, I'm not sure what could cause your problem.
Unread 02-02-2013, 19:29
ctccromer's Avatar
Animus
I'll doublecheck the setup tab monday, but we only have one joystick (it counts the whole controller as 1), and it was plugged into the same USB port I always use
EDIT: I love your team name! Legitimately made me laugh out loud
Team 3753 BulahBots
Unread 02-02-2013, 19:32
bvisness's Avatar
Oh. I suppose that's not your problem then.
If your code hasn't changed, and you've been messing with the electronics, then I would guess that the controller is not your problem.
Unread 02-02-2013, 23:10
ctccromer's Avatar
Animus
Its not that obvious either. For example, I traced the pwm wires THREE times. I know 100% without a doubt that they were plugged in the right slot, facing the right way. Yet the button that used to turn PWM 7 ("Shooter Arm") now turns PWM 5 ("Shooter Motor 1"). But Pwm 5 and 6 (Shooter Motors 1 and 2) worked with the same buttons as before. Except Pwm 5 went backwards.
Theres a lot that just doesn't make any sense. The CIM at pwm 5 might have the power cables backwards which would explain the backwards spinning, but everything else, i don't have a clue
Team 3753 BulahBots
Unread 03-02-2013, 00:57
What model of Logitech game controller are you using? Does it perhaps have a switch on the underside that changes its axis and button mapping?
Unread 03-02-2013, 07:36
I think Alan has it. Somewhere on the controller there is usually a button, I think they call it mode. It toggles between two different mappings of POV and axes. The drivers know nothing about and can't inform you that the joystick is in the wrong mode.
Greg McKaskle
Unread 03-02-2013, 10:53
ctccromer's Avatar
Animus
Yes it has X and D on the back. While one (i dont remember which) was far worse than the other, they were both very different from what they should have been according to the code and previous button mapping tests.
I'm using the Logitech F310 controller
I know it matters which PWM slot you plug motor controllers into, but does it matter which slot on the PDB you plug the motors into? I don't think it does, but IF it does, that could very well have caused it
Team 3753 BulahBots
Unread 03-02-2013, 11:08
The PDB circuits excluding the ones on the end for the cRIO, camera, and radio are interchangeable provided they have the right breaker installed. The SW knows nothing about them and they are not SW controlled.
Greg McKaskle
Unread 03-02-2013, 11:12
I think the F310 also has a mode button on the top.
Xinput is what you want to start with, not DirectInput.
Unread 03-02-2013, 12:20
ctccromer's Avatar
Animus
yep. We keep it on X and we keep the mode light off, though the only thing mode USED TO change (no idea now) was one axis
Team 3753 BulahBots
Unread 03-02-2013, 12:34
Kusha's Avatar
Kusha Kusha is offline
Crimpin' ain't easy
AKA: Kusha Gharahi
no team (Looking for a team)
Kusha is a jewel in the roughKusha is a jewel in the roughKusha is a jewel in the roughKusha is a jewel in the rough
One problem that we had was that tested code would suddenly start malfunctioning. 3 out of 4 drive motors started running on their own when they worked before. Our shooter wouldn't run and our spike/compressor would not work. After debugging we found out it was the ribbon cable that goes from the c-rio to the sidecar, suddenly everything was working again.
I hope this helps, if not then good luck.
https://kusha.me
Unread 03-02-2013, 13:42
ctccromer's Avatar
Animus
Originally Posted by Kusha View Post
After debugging we found out it was the ribbon cable that goes from the c-rio to the sidecar, suddenly everything was working again..
I'll be sure to check this monday, thanks
Team 3753 BulahBots
Unread 03-02-2013, 16:28
bvisness's Avatar
Really? We have always found that DirectInput (D) works far better for us than Xinput. (As for the Mode button, that only switches the functions of the + pad and the left analog stick. You should probably keep the Mode light off.)
Unread 03-02-2013, 18:32
We found using DirectInput gave us access to all the functions on our fancy gamepads last year, while Xinput mapped some of the shoulder buttons as axes that weren't supported by the Driver Station.
The PS2 game controllers we're using this year have a mode button that needs to be on in order for them to work right. With it off, one of the thumbsticks and half the buttons don't do anything we can detect.
