Go to Post I've learned never to say never when it comes to FIRST teams. - Karthik [more]
Unread 02-02-2013, 20:18
JM033's Avatar
JM033 JM033 is offline
AKA: J
FRC #0240 (Tempest)
JM033 is an unknown quantity at this point
Is vision processing on the crio plausible?
It's definitely possible, but is it plausible? I heard it takes up a lot of memory, and slows down the code. From my understanding the best way is such: (onboard comp/comp. dashboard)>(classmate w/ dashboard)>(crio).
What if you can turn vision tracking off and on when needed? Imagine this: a robot is lining up to shoot by the pyramid, standing still running no motors except lets say the shooter and a lifter/hopper. I push a button to do tracking, and tracking starts on crio, finds target, and shoots all the discs. Then tracking stops right after. With such an occurrence, will the tracking slow anything else down? It's not running the whole match.
And If it has a big impact on processing power/speed, how "lean" should the code on the crio need to be successful?...how lean?..how lean do you like your meat? just kidding..
Unread 02-02-2013, 20:25
bvisness's Avatar
bvisness bvisness is offline
Programming Mentor, Former Driver
bvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of light
Re: Is vision processing on the crio plausible?
Last year the vision processing slowed down our robot by an intolerable amount when we ran it on the cRIO. Every aspect of our code was lagging when we had vision running, which caused us to get all kinds of watchdog errors and other problems.
That was using an 8-slot cRIO, and I can't speak for the new 4-slot ones, but I think that running vision on the cRIO is not really worth your time. It's probably more worth your while to set it up on the dashboard and send rectangle coordinates over to the robot.
Unread 02-02-2013, 21:02
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
inkspell4 will become famous soon enough
How is it recommended for the vision to be processed on the drivers station?
Chesapeake Regional : 2013, 2012, 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
Unread 02-02-2013, 21:13
Even on an on-board PC image processing is still a pretty slow method of sensor feedback after the latency of the camera, networking and processing are accounted for. This means that it is generally advisable to use a faster, lower latency sensor to close the loop such as a gyro or encoders with the image processing providing the setpoint.
One consequence of this method is that you really only need to process a small number of images to align the robot. Process one image on demand->Wait until the setpoint is reached->Process another image to see if you're close enough->Repeat as necessary.
If using this type of on-demand alignment sequence it is unlikely you will notice the latency caused by the processing of the image relative to the time required to actually align the robot (provided your image processing is fairly efficient)
Unread 02-02-2013, 21:26
inkspell4's Avatar
I was thinking about on the driver station
Unread 02-02-2013, 21:50
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
I suspect if you'd performed a search you would have found numerous discussions about this.
First, don't make the mistake of believing that 'vision processing' is real-time. Even most of the fastest industrial robots take a single picture and work from that picture.
From that standpoint, the cRIO is more than capable of of processing a single frame in a fraction of a second. Or even more than a couple frames, if needed.
So, let's follow what you suggested: only run the vision processing when necessary. You certainly don't need to use it when you aren't trying to aim.
What most teams did last year was to take pictures only when the shoot button is pressed. Once the vision system finds a target that matches your parameters, it then calculates the postion and distance. Using that single number, it turns the robot or turret (or whatever) to the needed position.
Very few teams used off-board processing last year, and only a handful had the knowledge to run it at real-time speeds (341 comes to mind).
However, only analyzing pictures when needed and only getting one set of 'good' values to turn toward the target will not over stress your cRIO at all. If you're only running your CPU at 100% to process a couple of pictures in a fraction of a second, it's really not an issue. If you want to get really fancy, you could even turn all your other code 'off' (with a case structure) when you're running your vision routine while holding the shoot button. Be creative.
Unread 03-02-2013, 07:32
Tom said it well.
To add to that, the targets this year are huge. It should be possible to process them based on 160x120 images and definitely at the medium resolution. It should be sufficient to process just a few a second or on demand. It should be fine to process then at a lowered priority.
Greg McKaskle
Unread 04-02-2013, 21:28
JM033's Avatar
AKA: J
FRC #0240 (Tempest)
Tried today and It's terrible with camera resolution low and everything. Besides that, how would one go about taking a single picture from the axis camera and move motors to line up to target, based on the given x,y and distance values from that set frame? PID?
Unread 04-02-2013, 23:26
Use the information computed from a frame to determine how much to turn. Use a gyro to turn that much. Optionally, when you've finished the turn, repeat the process. Once you verify that you're facing the right direction, use encoders to move to the proper distance from the goal.
PID is often a good tool for controlling robot direction based on a gyro, and for controlling robot drive based on encoders.
Unread 05-02-2013, 06:53
Does terrible mean it didn't work, or just that the image was grainy and ugly.This isn't a beauty pageant, after all. Can you give details?
Greg McKaskle
Unread 05-02-2013, 07:31
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
You can probably use two cRIOs (one as a co-processor). We asked the GDC last year if this was allowed, and they said yes. The PCB also did not need to remain in the metal chassis (a huge weight savings). We ended up using the method mentioned earlier with a driver station laptop doing the processing.
To fit the image within the bandwidth constraints, the refresh rate and image quality had to be set low. It was good enough to work for image recognition, but won't win any image quality awards
Unread 05-02-2013, 09:03
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Yes it is possible and plausible, but there are a few special considerations. We did it last year, and got between 5-10 fps processing time depending on how clean our images were.
You need excellent illumination to create high-contrast images. I recommend two bright green LED ring-lights, or even more. You will also need to tune your camera's exposure settings to give you the most contrast as possible.
Here is a oldie but goodie whitepaper from team 67 on how to do this:
http://thinktank.wpi.edu/article/118
Why do you need to do this?
You need to keep the object recognition routines as simple as possible, so you need to start with very simple images. Black background with your object in bright green is your goal.
Here is Java code from our robot last year showing how we did this:
    public void processCamera() {
        if (camera.freshImage()) {
            try {
                //Take a snapshot of the current turret pot position
                curTurretPot = turret.getPos();
                colorImage = camera.getImage(); // get the image from the camera
                freshImage = true;
                //TODO: Tune these HSL values at the venue!
                binImage = colorImage.thresholdHSV(ImagingConstants.kHThresholdMin, ImagingConstants.kHThresholdMax, ImagingConstants.kSThresholdMin, ImagingConstants.kSThresholdMax, ImagingConstants.kLThresholdMin, ImagingConstants.kLThresholdMax);
                s_particles = binImage.getOrderedParticleAnalysisReports(4);
                colorImage.free();
                binImage.free();
                if (s_particles.length > 0) {
                    int lowestY = 0;
                    for (int i = 1; i < s_particles.length; i++) {
                        circ = s_particles[i];
                        //Find the highest rectangle (will have the lowest Y coordinate)
                        if (s_particles[lowestY].boundingRectTop > circ.boundingRectTop) {
                            if ((circ.boundingRectWidth > 20) && (circ.boundingRectHeight > 20)) {
                                lowestY = i;
                    topTarget = s_particles[lowestY];
                    //Send bounding rectangle info to SmartDashboard
                    // Check if the best top blob is bigger than 20
                    if (topTarget.particleArea > 20) {
                        xOffset = ((topTarget.boundingRectLeft + topTarget.boundingRectWidth / 2) - 160.0) / 160.0;
                        size = topTarget.particleArea;
                    } else {
                        xOffset = 0;
                        topTarget = null;
                } else {
                    xOffset = 0;
                    topTarget = null;
            } catch (AxisCameraException ex) {
                ex.printStackTrace();
            } catch (NIVisionException ex) {
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 05-02-2013, 11:52
MamaSpoldi's Avatar
MamaSpoldi MamaSpoldi is offline
Programming Mentor
AKA: Laura Spoldi
FRC #0230 (Gaelhawks)
MamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant future
Justin - this is the same approach we are taking to limit the "interference" of the image processing with the operation of the rest of the robot systems. We are running a very fast processing loop for all our code to enhance our control system capabilities, so we broke the processing into 2 steps to reduce the required image processing time to remain within our allotted loop time. It seems to be working for us so far but we have not done extensive testing as yet. Hope for both of us that this is a viable implementation strategy. Based on the comments here it seems very plausible.
Unread 05-02-2013, 17:05
splatter's Avatar
splatter splatter is offline
Cant Spell Robots With Out Rob
AKA: Robert
FRC #0271 (Mechanical Marauders)
Team Role: CAD
splatter will become famous soon enough
yes processing on the crio is possible but you will you should only proc. 1-3 frames per second to try and not overload the cpu.
FIRST Team 271
<Electrical, CAD>
http://www2.bayshoreschools.org/robotics/
