Go to Post "Don't you wish your drill bit was hot like mine?" - BariSaxGuy [more]
Unread 02-02-2013, 16:36
Team 2085 Team 2085 is offline
FRC #2085
Team 2085 is an unknown quantity at this point
Question Need help with infrared sensor
Hi, I'm using a 38kHz ir-LED and receiver module. However, I've had some trouble writing code for them. I think I figured out the receiver module and have wrote most of the code for it. I used a simple DigitalInput class and printed the value. It should be 1 if it doesn't receive anything and 0 if it does, right? The main problem I've had is making the LED output 38kHz. I'm trying to use a DigitalOutput class, so I wrote this:
DigitalOutput *irSender;
irSender = new DigitalOutput(2);
irSender->Set(true);
Can someone please tell me what I am doing wrong? I could really use any advice. Thanks
Unread 02-02-2013, 20:42
nuggetsyl's Avatar
nuggetsyl nuggetsyl is offline
FRC #0025
nuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond repute
Re: Need help with infrared sensor
Why are you using IR?
00,12Championship winner
03,06,08 Championship finalist
02A,03C,06N,08C,11N,12G Division winner
00,03,06,07,08,10,12 NJ / MAR winner
11 VCU winner
06,10 Las Vegas winner
12 MAR Mt Olive
red is for team 348
Unread 03-02-2013, 21:16
William Kunkel William Kunkel is offline
Programming Lead
AKA: Kunkel
FRC #0422 (Mech Tech Dragons)
William Kunkel is an unknown quantity at this point
How is your LED wired? Do you have a picture/diagram?
Unread 04-02-2013, 19:05
FRC #2085
It is a zx-irm receiver and a zx-irLed light.
We can make the LED light up but don't know how to get it to flicker at 38 kHz.
Unread 04-02-2013, 21:20
To get it to flicker at any frequency, provide it with that frequency on its input.
What are you trying to do with this sensor? There might be a better way to accomplish it.
