Go to Post I've got much more out of FIRST ever since I stopped and realized I can gain so much more from trying to improve my current team's situation rather than complain about teams who have more. - AdamHeard [more]
  #31   Spotlight this post!
Unread 02-02-2013, 21:08
kenfox kenfox is offline
FRC #3322 (Eagle Imperium)
kenfox is a glorious beacon of lightkenfox is a glorious beacon of lightkenfox is a glorious beacon of lightkenfox is a glorious beacon of lightkenfox is a glorious beacon of light
Re: Velocity PID Programming: Terms dependent on time
My concern was along the following lines [not properly restoring interrupts] ... then you can't reliably use cli in your application code.
That may be a problem, but I couldn't figure out a way to test it. I/O interrupts in WPILib are partly handled by the FPGA. Reading the FPGA clock looks similar to reading a global variable from the FPGA, so if there are bugs with interrupts, it probably affects more than just the clock. Reading the PPC clock is so fast it probably doesn't mess with interrupts--I'm not even sure if it's a system call.
What the overhead of accessing the FPGA, compared to reading the PPC clock?
FPGA clock access takes 50x the PPC clock.
Over 100,000 calls, mean clock access times were:
FPGA = 0.02320 msec
PPC = 0.00048 msec
vxWorks = 0.00172 msec
The max elapsed time between subsequent calls was around 0.002 msec for all of them so my test was getting time sliced and the reported numbers are a bit high.
The FPGA and PPC clocks have similar accuracy. I was wondering if the PPC clock wouldn't accurately track the FPGA clock, but elapsed times over short periods are within the error of my measurement.
We also experimented measuring system performance with an external clock by generating a digital signal and capturing it with a logic analyzer sampling at 8MHz. We captured good data watching our periodic teleop code, but ran out of daylight before digging into system clock stuff.
  #32   Spotlight this post!
Unread 03-02-2013, 09:28
I won't claim to be an authority on the LV-RT side of this, but I can help out a bit.
The ms timestamp in LV is very portable and has been in LV since the mac days. It is often used for simplicity when doing slower I/O and timing. Often, NI would have a card on the bus with a better time source that was synched to the I/O, but it would generally need to keep that timer operation controlled by the driver or the board. Bringing out out to user code in the loop would generally not make sense.
RT OSes change that. You'll find there are numerous clocks and ways to access them. The simplest step is to use the RT Tick Count. In the attached image, it is configured for microseconds and I did a quick jitter test at time critical priority. It is zoomed in, but this is how it looked for the 100,000 iterations I took. Again, I'm not the authority, but this looks like it is based on the OS timer and clearly has some overhead. But it is a simple drop in replacement of the ms ticks and works for the OP question.
For the PPC timer, I think you would use RT Get Timestamp.vi. I say think because I now realize that I don't have all of RT installed. I have much of it synched from a source server and not all of it is functional. If you read the help on the node, there is an example at the bottom for measuring an operation using this node. But I can't run it to give data. I'm curious to see if typical FRC install can.
For the FPGA timer, access from RT code is via the serial bus and while available, the better use of this timer is within the FPGA circuit itself. This gives you implicit access to the 25ns clock that is driving your circuit.
Greg McKaskle
  #33   Spotlight this post!
Unread 03-02-2013, 20:14
Here's far more than anyone probably wanted to know about the clocks available with WPILib C++. I used 10 runs of 1000 clock accesses for each of the 3 clocks. I did this with the default task (thread) priority, high task priority, and high priority locked (which prevents the task from being scheduled off the cpu unless it explicitly blocks).
The clock of choice is definitely the PPC clock: Timer::GetPPCTimestamp.
I experimented more with external timing with a signal analyzer and the external timing matched the PPC clock to +/- 4 microseconds. I only measured durations between 0.5 msec and 1.5 sec. It's kind of fun to see code profiled on a signal analyzer.
Here's the inner loop of the test:
#define RUN_TIMER_TEST(F) \
elapsed = last = Timer::GetPPCTimestamp(); \
for (j = 0; j < NumInnerIters; ++j) { \
	now = F(); \
	dt = now - last; \
	if (j > 0) { \
		if (dt > max_dt) max_dt = dt; \
		if (dt < min_dt) min_dt = dt; \
	else { \
		max_dt = 0.0; \
		min_dt = 1.0; \
	last = now; \
elapsed = Timer::GetPPCTimestamp() - elapsed; \
avg_dt = elapsed / NumInnerIters;
Here's the raw data from a cRIO (older 8 module hardware):
Clock name,
Avg time per call (measured by PPC clock),
Min delta time,
Max delta time (as returned by clock under test)
TIMING TEST - Normal FRC priority, task unlocked
FPGA,0.00002835,0.00002300,0.00088700
FPGA,0.00002785,0.00002300,0.00080900
FPGA,0.00002644,0.00002300,0.00065500
FPGA,0.00002736,0.00002300,0.00087600
FPGA,0.00002860,0.00002300,0.00213800
FPGA,0.00002668,0.00002300,0.00062900
FPGA,0.00002698,0.00002300,0.00109000
FPGA,0.00002833,0.00002300,0.00179700
FPGA,0.00002706,0.00002300,0.00065600
FPGA,0.00002622,0.00002300,0.00064400
GetTime,0.00000171,0.00000143,0.00013781
GetTime,0.00000154,0.00000143,0.00002217
GetTime,0.00000186,0.00000143,0.00031662
GetTime,0.00000300,0.00000143,0.00085568
GetTime,0.00000155,0.00000143,0.00002766
GetTime,0.00000171,0.00000143,0.00014114
GetTime,0.00000154,0.00000143,0.00001907
GetTime,0.00000347,0.00000143,0.00190639
GetTime,0.00000153,0.00000143,0.00001216
GetTime,0.00000154,0.00000143,0.00001144
PPC,0.00000043,0.00000042,0.00000076
PPC,0.00000094,0.00000039,0.00051412
PPC,0.00000049,0.00000042,0.00006042
PPC,0.00000043,0.00000042,0.00000052
PPC,0.00000044,0.00000039,0.00001458
PPC,0.00000043,0.00000042,0.00000055
PPC,0.00000044,0.00000042,0.00000924
PPC,0.00000043,0.00000039,0.00000045
PPC,0.00000043,0.00000039,0.00000736
TIMING TEST - Highest priority, task unlocked
FPGA,0.00002249,0.00002100,0.00005700
FPGA,0.00002248,0.00002100,0.00005100
FPGA,0.00002251,0.00002100,0.00006300
FPGA,0.00002252,0.00002100,0.00005500
FPGA,0.00002249,0.00002100,0.00005100
FPGA,0.00002248,0.00002100,0.00004900
FPGA,0.00002249,0.00002100,0.00005000
FPGA,0.00002250,0.00002100,0.00004600
FPGA,0.00002248,0.00002100,0.00006000
GetTime,0.00000156,0.00000143,0.00002623
GetTime,0.00000155,0.00000143,0.00002289
GetTime,0.00000157,0.00000143,0.00002337
GetTime,0.00000155,0.00000143,0.00001884
GetTime,0.00000159,0.00000143,0.00002933
GetTime,0.00000156,0.00000143,0.00002670
GetTime,0.00000157,0.00000143,0.00002551
GetTime,0.00000157,0.00000143,0.00002885
GetTime,0.00000155,0.00000143,0.00002384
GetTime,0.00000155,0.00000143,0.00001431
PPC,0.00000043,0.00000042,0.00000094
PPC,0.00000045,0.00000039,0.00002179
PPC,0.00000046,0.00000042,0.00002609
PPC,0.00000045,0.00000039,0.00002306
PPC,0.00000043,0.00000042,0.00000045
PPC,0.00000044,0.00000039,0.00001088
PPC,0.00000044,0.00000042,0.00000988
TIMING TEST - Highest priority, task locked
FPGA,0.00002047,0.00001900,0.00005600
FPGA,0.00002048,0.00001900,0.00006400
FPGA,0.00002048,0.00001900,0.00006900
FPGA,0.00002047,0.00001900,0.00006300
FPGA,0.00002046,0.00001900,0.00006900
FPGA,0.00002047,0.00001900,0.00005000
FPGA,0.00002048,0.00001900,0.00004700
FPGA,0.00002046,0.00001900,0.00006400
FPGA,0.00002049,0.00001900,0.00006800
FPGA,0.00002046,0.00001900,0.00005100
GetTime,0.00000155,0.00000143,0.00002122
GetTime,0.00000156,0.00000143,0.00002432
GetTime,0.00000158,0.00000143,0.00002551
GetTime,0.00000160,0.00000143,0.00002837
GetTime,0.00000157,0.00000143,0.00002694
GetTime,0.00000156,0.00000143,0.00002766
GetTime,0.00000155,0.00000143,0.00002146
GetTime,0.00000155,0.00000143,0.00002623
GetTime,0.00000157,0.00000143,0.00002432
PPC,0.00000043,0.00000042,0.00000085
PPC,0.00000046,0.00000039,0.00002967
PPC,0.00000043,0.00000042,0.00000064
PPC,0.00000045,0.00000042,0.00001970
PPC,0.00000043,0.00000042,0.00000058
PPC,0.00000044,0.00000039,0.00000985
PPC,0.00000044,0.00000042,0.00001009
