Go to Post Also, if Beatty fielded a refrigerator we'd still pick them; how can you not - "all they ever do is win". - Gary Dillard [more]
Unread 02-02-2013, 20:53
thisOrrthat thisOrrthat is offline
I <3 robots
AKA: Luke Orr
FRC #1730 (Team Driven)
thisOrrthat will become famous soon enough
Quick Welding Question
We have a carbon fiber box with an aluminum support attached to it. Is there a way to weld to the aluminum with out damaging the carbon fiber under it?
Luke
CAD
Build
Media
Animation
FRC Team Driven 1730
Unread 02-02-2013, 20:59
Happy Birthday! Blondie3160 Blondie3160 is offline
FRC #3160 (F.R.O.G.)
Blondie3160 is an unknown quantity at this point
Re: Quick Welding Question
If its a small weld you could use a heat sinc, you could try putting another piece of aluminum there to get the heat off it, youd have to do it fast. maybe a spacer that doesnt conduct heat (stainless sheet metal between the two would be best). [im writing what our mentor told me so i may have missed one way that he said but he said all that]
Blondie3160
Unread 02-02-2013, 21:00
Basically just try not to heat it too much or something close
Blondie3160
EricH EricH is online now
I asked my dad (who used to work with composites for a living). His first comment did not have to do with welding, but with a galvanic issue. Apparently, aluminum and graphite don't like each other, and the effect is accentuated by moist environments (which would probably include at least part of Missouri). It's a slow process, but you may want to add something between the two and hope it hasn't started.
His second comment was that the heat will transfer. If you can remove the box from the aluminum, that's your best bet. Otherwise, use some way of getting the heat off of the aluminum if you can.
Unread 02-02-2013, 21:01
pfreivald's Avatar
AKA: Patrick Freivald
This is good advice in general... Use as big a heat sink as you can, weld quickly or in very small, very spread out periods. My general answer would be: probably not, unless you disconnect them.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 02-02-2013, 21:07
I <3 robots
AKA: Luke Orr
Thanks for your help guys, Ill let you know how it goes.
Luke
CAD
Build
Media
Animation
Unread 02-02-2013, 21:10
WELDERBOSS WELDERBOSS is offline
FRC #3255
WELDERBOSS is an unknown quantity at this point
The composit will warp not likly to be good to TIG weld with it on contact.
