Go to Post FIRST gives everyone lots of practice in getting used to late nights. - waialua359 [more]
Unread 18-01-2003, 21:20
TOHSlancer TOHSlancer is offline
TOHSlancer is an unknown quantity at this point
Drill motor wobble?
ERrrm, we have a small problem.. After attaching the transmission to the drill motor the shaft develops a slight wobble. Nothing very very bad but still pretty bad. I have made sure the whole motor is mounted straight and the shaft is in a straight line. Anybody know of a way to fix this problem?
Unread 18-01-2003, 21:37
Andy A. Andy A. is offline
Getting old
FRC #0095
Is the gearbox attached? Does the output shaft of the motor wobble? Have you taking the gearbox apart to remove pins or such?
Lots of questions before anything can really be said.
-Andy A.
Unread 18-01-2003, 21:40
Red face
wut do you mean take the gearboxes apart to remove the pins? There are pins? eh? Please send directions or a link please? Help much appreciated. The output shaft of the motor has no wobble. The gear box is attached.
Unread 19-01-2003, 18:12
jrgrim12 jrgrim12 is offline
Let's have fun!
#1022 (ArcherGEeks)
jrgrim12 will become famous soon enough
Send a message via AIM to jrgrim12
Our wobbles also. I don't think it's anything you did. i think the part that were sent in the kit aren't exactly on center. Ours was about .005-.010 out. It's not much but it can be enough to make things wobble. If it's a big problem then you may have to machine your own. We even had to finish machining the ones that were sent to us. They forgot to ream the hole.
James Grim
www.youthbotin.org
www.ztspeedandfab.com
Unread 21-01-2003, 21:52
caffel caffel is offline
AKA: Charlie Affel
FRC #0423
caffel is an unknown quantity at this point
We had a wobbly aluminum coupling half too.
We decided to set itaside as spare & ordered another.
CA 487
Charlie Affel,
Mentor 423
Unread 11-02-2003, 00:36
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
We also had the out of center Al cupling, we made a new one, also, seems like the quality of lots of things are lacking this year
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 11-02-2003, 00:46
Suneet Suneet is offline
Physicist-In-Training
None #0599 (RoboDox)
Suneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to behold
Send a message via ICQ to Suneet Send a message via AIM to Suneet
Eeek, AHHH! We just tried the coupling too (in our chippy-Drill mating box) and WOW are they off. We'll have to make our own too. I'm disappointed.
Unread 11-02-2003, 00:47
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I am so glad ours are not the only ones. Now I can use this thread as an excuse for my junky alignment.
Unread 11-02-2003, 19:53
blindguy blindguy is offline
blindguy is an unknown quantity at this point
Send a message via AIM to blindguy
The reason the hex peices are off is because of the plastic coupling. Near that plastic thing in the middle the edges warp out a little, and not the same on all sides. the way our team(me) resovled this problem what to remove the plastic from the center of the coupling(so you could shove a hex shaft all the way threw). Then I stuck the part that connects to the motor in so all the hex part was hidden. Now the other one will end up sticking a little bit further out but its ok cuz what you just did is shift the coupling over a bit.
Matt
Unread 11-02-2003, 20:10
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Ehhh. As my physics teacher says it is close enough. It is close enough so that it works but not perfect. Btw I do not think this is an accident considering almost every signal team has this same situation(including ours).
Unread 11-02-2003, 22:55
mav's Avatar
mav mav is offline
mav is an unknown quantity at this point
Send a message via AIM to mav
ya we had the same wobble problem but it only happend in low gear and went away in high speed
Portable cordless drill press Gui Cavalcanti Technical Discussion 25 03-08-2003 22:21
drill motor mounts- again Jeff Sharpe Motors 6 07-04-2003 23:20
Emergency drill trade/sell Anarkissed General Forum 3 16-02-2003 22:37
Q&A Discuss: HOT drill motors CD47-Bot Extra Discussion 1 27-01-2003 13:31
