Go to Post There is nothing cooler than engineers playing rock music. - Jay Trzaskos [more]
Unread 02-02-2013, 13:20
Tzarus Tzarus is offline
FRC #4137
Tzarus is an unknown quantity at this point
bumper guideline question
good day chief delphi forums!
i have a request
i need clarification on rule r29 of the bumpers regarding the "minimum of one inch at each end of the bumper being backed by the frame perimeter."
what does it mean?
Unread 02-02-2013, 13:28
Chris is me's Avatar
AKA: Pinecone
Re: bumper guideline question
It means there needs to be a member of your frame supporting the bumper for at least an inch at each end. For teams that don't have a solid frame member throughout their frame perimeter, this means they have to add support structure at the corners no matter how else the bumper is supported.
Unread 02-02-2013, 21:42
Andrew Zeller's Avatar
Andrew Zeller Andrew Zeller is offline
Mechanical Engineering at UA
FRC #1716 (Redbird Robotics)
Andrew Zeller has a spectacular aura aboutAndrew Zeller has a spectacular aura aboutAndrew Zeller has a spectacular aura about
R29
BUMPERS must be supported by the structure/frame of the ROBOT (see Figure 4-6). To be considered supported:
a minimum of 1 in. at each end of the BUMPER must be backed by the FRAME PERIMETER,
By saying "supporting" do you interpret the rule to mean that a part of the robot must be fastened to the bumper for at least an inch at each end, or that there must be a be a part of the frame simply present there, "backing" the bumper?
FIRST ROBOTICS TEAM 1716 Redbird Robotics
2012 Wisconsin Regional Judges Award
2012 Wisconsin Regional Quarterfinalists
http://www.frc1716.org/
Unread 02-02-2013, 21:55
The rule says supported. What that means is that there has to be something there. Whether it's just backing or goes to fastening will depend on a number of other items, including what is in the middle of the bumper. If there was a longish gap, for instance, I would expect some fastening in that last inch. If it were solid, I would probably not expect fastening in the last inch.
If your bumper can move away from the frame with little effort, it probably isn't secure enough.
Unread 04-02-2013, 08:59
Guys,
All the bumper rules must be followed. To be 'supported' the bumper has to be mounted on the frame such that the figures shown in the rules are satisfied. the 1" overhang prevents teams from having bumpers be cantilevered beyond the supporting frame by more than inch, also shown in the drawings in this section.
