Go to Post Wow, almost seems unfair to have that many nice people in one place. Isn't it possible to overload on cool? - Molten [more]
Unread 03-02-2013, 00:20
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
Sensor for finding out angle?
Any sensor we can use to determine the angle of, say, our launcher?
Gyro seems interesting but we'd have to integrate the rate of change of the launcher angle; any more reasonable method of finding angle?
Thanks.
FTC Teams 5257, 6568 & FRC Team 3992
2014 FTC WORLD CHAMPIONS
14 Trophies in 3 Years
Unread 03-02-2013, 00:22
Re: Sensor for finding out angle?
Thanks.
Use a potentiometer.
Unread 03-02-2013, 00:23
ksafin's Avatar
AKA: Kirill Safin
In what fashion?
We've never delved into analog devices for use on the robot - so we're pretty blank on how we'd do that.
However, can we actually get angle from the gyro sensor? http://www.wbrobotics.com/javadoc/ed...libj/Gyro.html getAngle() seems to suggest so..
Unread 03-02-2013, 00:52
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
A potentiometer is just a voltage divider. One end gets wired to power the other to ground and the middle is your signal that will vary between 0-5v. Attach it to the pivot point and the voltage will correspond to where it is in its travel. No it does not tell you the angle directly but you don't really need that info you want to be able to drive it to a certain position. So you command your motor to run until you get the desired voltage output and then stop.
Unread 03-02-2013, 01:09
simpsonboy77 simpsonboy77 is offline
AKA: Garrett Dicken
FRC #0041 (RoboWarriors)
simpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond repute
I would recommend a potentiometer as well. If your launcher always starts at the same location, a quadrature encoder would work as well. You can also use a magnetic encoder, although i don't recommend this.
I do not recommend a gyro as any small amount of drift will greatly affect your shooter's accuracy.
2017 Shenzhen, China Regional CSA
2013 - Present MAR Control System Adviser and FTAA
2009 - Present Programming an Electrical Mentor Team 41
2007 - 2008 Team 41 Lead Programmer, Electrical
2005 - 2008 Team 41 Member
2008 NYC Regional Winner
Unread 03-02-2013, 01:17
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
In what fashion?
Gyros give yaw-rate information from which angle can be derived. The issue is that it does not give position relative to the robot, it gives position relative to the position it was in when it was last initialized. Depending on the direction your robot is facing, straight ahead could be any angle. Also, the angle tends to drift over time as errors accumulate so accuracy would degrade as the match progressed.
Potentiometers are a much better option since they will give you position relative to the robot with decent repeatability.
Unread 03-02-2013, 01:22
Ankit S.'s Avatar
Ankit S. Ankit S. is offline
FRC #2489 (The Insomniacs)
Ankit S. has a spectacular aura aboutAnkit S. has a spectacular aura about
We were thinking of using an accelerometer for our shooter, but we will hav to see how the vibration effects the reading first.
If that doesn't work out, we may use a potentiometer instead.
FRC 2489 - The Insomniacs
Alumnus
2489, 3189, & 701 - The Green Alliance - 2013 Sacramento Regional #6 Alliance Captain and Champions!!!
971, 254, & 2489 - 2011 CalGames Champions. Thanks 254 and 971!!!
Unread 03-02-2013, 01:29
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
I don't recommend that. Accelerometer readings can be affected by any small jerks or movement, probably even the vibration of the shooter wheels. Programming would also be more complicated. Potentiometers are more consistent, less noisy and easier to program.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 03-02-2013, 02:05
foote stepped in
AKA: E. Foote
FRC #0868
Just brainstorming a few ideas. If you don't like the idea of potentiometer, you
Could use a magnet and a 2 axis magnetometer (actually, you might be able to get away with just a single axis if you set it up right).
Could also use a 2 axis accelerometer (mount it to your shooter and measure which way gravity is pointing).
Could also use a rotary encoder.
could probably use your webcam if you set it up properly.
Or you could use a strain gauge if you attach a spring to your shooter.
But most people have reasonable success with a potentiometer.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It. Like our values? Flexware Innovation is hiring!. We're looking for Senior Automation, Software, and System Engineers. Check us out!
Unread 03-02-2013, 02:07
Custom User Title
AKA: Cal
Another reasonable possibility (that may even work better than a potentiometer) is to use an encoder and limit switches to calibrate the ends of the device's travel
