Go to Post I'm going through waves of excitment and panic all at the same time. - je2164 [more]
Unread 02-02-2013, 10:07
Avihu Avihu is offline
FRC #4661
Avihu is an unknown quantity at this point
Gyro
how to connect the Gyro to the robot ? and how do we resive its data in the driver station?
Unread 02-02-2013, 10:22
Re: Gyro
The Kit gyro is an analog device.
Use the pins labels rate, not temp.
Connect via PWM cable to the Analog Breakout.
Read in code using the special Gyro functions.
Unread 03-02-2013, 04:34
FRC #4661
Re: Gyro
ok but how to connect the wires? where is + and the - ? and the data ?
Unread 03-02-2013, 10:16
Re: Gyro
Use a standard PWM cable.
Plug one end into the gyro pins labeled "rate" with the ground wire on the pin by the word "rate."
The other end of the PWM cable plugs into one of the Analog Breakout ports with the ground pin to the back.
Unread 03-02-2013, 12:35
Re: Gyro
The LabVIEW "Gyro" example includes a diagram showing how to wire a generic analog gyro sensor.
