Go to Post A few months from now I'll be walking to school and then I'll suddenly be attack by a rogue robot trying to feed me a golden ball or something wont I? - Marcel [more]
Unread 03-02-2013, 19:13
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Re: Predict the most violated rule of the year
I think these two rules will be enforced more often than others:
G18-1
Strategies aimed solely at forcing the opposing ALLIANCE to violate a rule are not in the spirit of FRC and are not allowed. Rule violations forced in this manner will not result in assessment of a penalty on the target ALLIANCE .
Violation: TECHNICAL FOUL
G30
Regardless of who initiates the contact, a ROBOT may not contact an opponent ROBOT
contacting its PYRAMID or
touching the carpet in its LOADING ZONE.
Violation: FOUL. If purposeful or consequential, TECHNICAL FOUL. If an opponent's CLIMB is affected, each affected opponent ROBOT will be awarded points for a successful Level 3 CLIMB.
Let's say your robot is shooting from a protected position. A defender comes to block you by parking very close in front of you. You push the defender back while still in a protected position.
If you make contact, a penalty is going to be called one way or another. Either your opponent will be penalized per G30, or you will be penalized per G18-1.
Given how many shooters will try and shoot from a protected position, I can see this situation happening quite often...
To me the call is similar to the Block/Charge in basketball. A offensive player goes up for a shot, and contact is made with a defender. As soon as contact is made, it's going to be a blocking foul on the defender, or a charge call on the shooter.
In life, what you give, you keep. What you fail to give, you lose forever...
