Go to Post It's all about that bumper quality. - Gutherie88 [more]
Unread 03-02-2013, 11:59
swwrobotics's Avatar
swwrobotics swwrobotics is offline
FRC #2900 (The Mighty Penguins)
swwrobotics is an unknown quantity at this point
WHAT IS THE PYRAMID HEIGHT?
Hey everyone, my team is really confused about the heights of the pyramid rungs and we would like to get some clarification on the height of it. My team thinks that the 1st rung is measured 30 inches from the floor to the middle of the rung, based on the figure 2-7 drawing in the game manual (http://frc-manual.usfirst.org/viewItem/3#2), which the Q&A people said to refer to. However, if you watch the field tour video, one of the guys clearly states that the 30 inches is measured from the floor to the top of the first rung. (http://www.youtube.com/watch?v=U8E27...y8wIL&index=1).
So does anyone have a good idea of what the right measurements are? Has anyone downloaded the CAD of the field and checked? I'm really sorry about this but I feel that this has been unclear to a lot of people.
Unread 03-02-2013, 12:22
GaryVoshol's Avatar
Cogito ergo arbitro
Re: WHAT IS THE PYRAMID HEIGHT?
The official field drawings have the official measurements. Just like the manual has the official rules - anything you hear in the game animation doesn't count.
(since 2004)
Unread 03-02-2013, 12:28
EricLeifermann's Avatar
EricLeifermann EricLeifermann is offline
That was a short break
FRC #2826 (Wave Robotics)
The video says that level 1 goes from the floor to the top of the 1st rung, it does not say that the top of the rung is 30" off the ground.
2012-2016 Wave Robotics Team 2826
Unread 03-02-2013, 12:30
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We'll probably build our robot to work with a 2.5" range of possible bar heights.
If you can't do that, maybe you could make it adjustable over a .75" range, just in case.
Good luck!
Unread 03-02-2013, 12:34
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
The solidworks model puts the the center of the first rung at 29.916" above the floor. Slightly less above the pyramid base, obviously. Those are the drawings the field was constructed with, so they're likely accurate within tolerances.
Unread 03-02-2013, 12:51
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Unless you have an official field to build your robot on, build with error in mind!
Unread 03-02-2013, 13:09
Wow, thanks everyone for the advice! This actually helped a lot. My team will probably try to make our design adjustable if it comes to it just in case.
Unread 03-02-2013, 13:15
Joining the 900 Meme Team
FRC #0079
Even then. Fields do vary. My personal favorite was in 08 when the overpass started to sag.
Unread 03-02-2013, 19:44
Expect up to a 4" tolerance in overall field dimensions, and 1/4" in any given assembly. IIRC, that's what the manual states, or close to it. If you need it to be within 1/8", you don't have enough leeway.
Unread 04-02-2013, 08:55
pfreivald's Avatar
AKA: Patrick Freivald
It took us too many years to learn that all FRC values are nominal...
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
