Go to Post Glue it, screw it, bolt it, rivet it, weld it. If the design is flawed it will fail. - Gdeaver [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Unread 09-01-2013, 18:53
axel_grease's Avatar
axel_grease axel_grease is offline
Build/ Jedi
FRC #2557 (Sota Bots)
axel_grease is an unknown quantity at this point
Scouting for Ultimate Ascent
What are your teams emphasizing in your scouting system? Are you designing a scouting system from scratch for this game?
Cheers,
Courtney V, SOTABots head scout. C/o axel_grease.
Unread 10-01-2013, 16:15
Jonathan K. Jonathan K. is offline
FRC #2073
Jonathan K. is an unknown quantity at this point
Re: Scouting for Ultimate Ascent
We're still trying to figure out what the deciding and most important factor in the game will be. Last year we didn't realize how important the bridge was until it was too late.
With the abundance of electronics and smartphones we'll probably end up implementing an electronic scouting system instead of traditional clipboard and pen.
FRC:3250 Kennedy Robotics - 2012
FRC:2073 Eagle Force - 2013
Unread 10-01-2013, 18:04
sergioCorral842's Avatar
sergioCorral842 sergioCorral842 is offline
College Student
FRC #0842 (Falcon Robotics)
sergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to behold
We will be using a scouting system that a team member and I made this year. We posted a thread about it here : http://www.chiefdelphi.com/forums/sh...ghlight=falcon
We have updated it to this years game all we are missing are pictures. I will post the download link soon so any team that needs a scouting software can use it.
Unread 10-01-2013, 18:19
stundt1's Avatar
stundt1 stundt1 is offline
Steve
FRC #4930 (Electric Mayhem)
stundt1 will become famous soon enoughstundt1 will become famous soon enough
We will be using a paper scouting system with data entry into a spread sheet.
Over the off season we halfway developed a scouting app. But complications with not enough devices/ no way to charge them. Led to us to to cancel the project. It had great potiential.
Steve
-Programming Mentor
- Team 578 Alumni
Unread 11-01-2013, 11:21
jlmcmchl jlmcmchl is offline
FF - The Breakfast Company
AKA: Jordan McMichael
FRC #0027 (Team RUSH 27)
jlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud of
Team RUSH will be using a multi-part scouting system from the ground up. Last year, we created a similar system using iPads, which worked well. However, the main issue was that between matches, the Scouting Captain had to collect the iPads and download the data to a computer, which took almost as long as the time between matches for all 6 iPads. Another issue was that once competitions got to higher match numbers, copying over all of the data(we stored the backup data on the iPads) took even longer, slowing us down.
This year, we will be writing the Scouting App from scratch. In Xcode, I already have a working prototype for custom navigation, and will be implementing the rest of the user interface over today and tomorrow.
We will be emphasizing an efficient way to collect the information, whilst also having a comprehensive amount of information on each robot during the match. The Scouters will be using iPad Minis which we purchased recently for Scouting. We also have a central iPad Mini, to work as a sort of server. For reference, think of the Scrabble game made for iOS a few years back.
The Scouters will be sending their data to the central iPad Mini. This is where all the important calculations are done. When the Scouters send their data, I can send them back the next team they will be scouting. For each match, I will also create match predictions, and if Team RUSH is in that match, I will send the results down to our pits, where out drive team will use this to create a strategy with our alliance partners.
If you're wondering, I will be sending both apps to the App Store by the end of build season, along with a Readme for everything you need to know about the app.
Unread 11-01-2013, 11:47
D.Allred's Avatar
D.Allred D.Allred is offline
FRC #4451 (Rat Rod Robotics)
D.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond repute
Your system sounds great! What communication method will you use to synchronize the scouting iPads with the master unit?
Unread 11-01-2013, 13:21
Bluetooth, and a system similar to how Game Center allows for synchronous communication between devices.
Unread 12-01-2013, 18:45
junefish's Avatar
junefish junefish is offline
CAD . . . so easy yet so hard . . .
Team Role: Electrical
junefish is an unknown quantity at this point
We are updating last year's scouting program (computer/smartphone/tablet) to make it game-specific. Right now we probably have too many fields, so I'm anticipating deleting some on the Practice day of our first regional.
~junefish
Thirty-nine decimal places of pi suffice for computing the circumference of a circle girding the known universe with an error no greater than the radius of a hydrogen atom.
Unread 12-01-2013, 19:09
Billfred's Avatar
Billfred Billfred is offline
With Palmetto at Week 1, we're more or less going to have to scout in case we come out on the right end of the crap shoot.
My vision for scouting is determining a couple of things:
1) Scoring contribution in total
2) Disc efficiency (points equal, a team that loads 10 discs gets the nod over a team that loads 18)
3) How you hang at the end of the match. (On the off chance that your hanging technique would prevent another prospective partner from doing so.)
4) The usual did-you-really-stink-it-up stuff--yellow cards, DQs, breaking, no-shows...
Unread 12-01-2013, 22:17
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
I'm thinking of an elaborate system which entails having 6 students in the stands at all times observing each individual robot. We'll record:
1. Number of discs scored
2. Time from collection to shot
3. Score distribution. Where the scores were, how many, etc.
4. Speed range using qualitative responses. I.E Fast, moderate, slow.
5. Pyramid attempts and timings.
We'll come up with some weighting system to rank all of the teams at the event in terms of these stats and use that to determine our preliminary priority pick list. The secondary priority will be based on pit observations and talking with the team members.
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
Unread 12-01-2013, 23:57
math311's Avatar
math311 math311 is offline
FRC #2077 (LaserBots)
math311 is an unknown quantity at this point
My team is made up of many freshmen, so I worry that our scouting may overwhelm them, but our sheet is including (this WILL change):
1. Offensive or Defensive
2. What they do in autonomous
3. # of "bee's" retrieved in tele
4. Shooting in tele
5. Climbing
6. Fouls.
Unread 03-02-2013, 21:16
Lemonilla's Avatar
Lemonilla Lemonilla is offline
FRC #1189
Lemonilla is an unknown quantity at this point
Team 1189 is writing theirs in batch (widely know as MS-DOS). We plan on measuring points scored by both teams (before hanging is added), and points scored by hanging. That way only one person needs to scout.
Defensive robots will have a lower average number of points scored on them (over all their games) than an offensive robot.
Unread 03-02-2013, 21:38
CalTran's Avatar
CalTran CalTran is online now
MST Rolla Senior
Team 2410 will be using a scouting app that we created and will be making open source at the end of season. As for right now, you can download it from the Google Play store (Search "2410"). As of right now, it can be utilized by any team with at least 6 smart phones and a computer with bluetooth capability. More information is in the link above.
Academic Student (Forever)
Unread 03-02-2013, 23:35
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
Here ya go: https://play.google.com/store/apps/d...ingapplication
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
Unread 04-02-2013, 19:54
Alan2338's Avatar
Alan2338 Alan2338 is offline
Former Team Leader/Driver - Alumni
AKA: Alan Cabiness
FRC #2338 (Gear it Forward)
Alan2338 will become famous soon enough
We are planning on doing a remote scouting system for the first time. We will have 6 laptops transmit scouting data to a central computer compiling the data on an excel spreadsheet.
One feature everyone should think to add to their scouting is standard deviation.
Good for picking a reliable alliance partner, or a wild card just to try to win a difficult match.
[IMG] code is Off
