Go to Post Don't bring a distraction to the field. - Al Skierkiewicz [more]
Unread 03-02-2013, 22:20
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Plasma Cutting Team 2470's Frisbee Launcher
Team 2470 - The Blitz Team starting cutting out their frisbee launcher with the school's new plasma cutter today. The launcher is assembled from 6 sheets of steel, you can see 5 of the sides in the below CAD drawing. We decided to add a sixth side today for stability. You can see a video of the plasma cutter in action here. http://www.youtube.com/watch?v=RUpf_stUnaw
CAD Drawing
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 04-02-2013, 00:20
davepowers's Avatar
davepowers davepowers is offline
Currently dreaming about robots
AKA: Danger Dave
FRC #1687 (Highlander Robotics)
davepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud of
Re: Plasma Cutting Team 2470's Frisbee Launcher
What made you guys chose steel over a much lighter aluminum? I can't foresee a shooter producing more load than some .090 or .125 could handle.
Other than that, it looks good! I love me some nice CNC plasma cutting!
David Powers - Deans List Finalist - WPI 17' - Bleed True Clothing
1999-xxxx FRC228, GUS Robotics Inc.
2013-xxxx FRC1678, Highlander Robotics
Unread 04-02-2013, 00:46
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Second the aluminum suggestion. We've cut 0.050" and a tiny bit of 0.090" 6061 on a CNC plasma cutter with no issues. The blowout/edge finish is much worse than a waterjet or laser, and it takes a bit more manual cleanup, but definitely usable for FRC.
Are you planning on supporting the end of that shaft (where I assume there is a CIM mounted to a wheel)? It's highly recommended to support both ends of a shaft when possible.
Kettering Motorsports
Unread 04-02-2013, 12:09
ehochstein's Avatar
AKA: Evan Hochstein
FTC #5943 (ESGM)
I agree with you guys, I would prefer aluminum but when your sponsor donates the steel and offers to weld it for you, we can't complain. We would have just purchased some aluminum and sent it to the sponsor for welding but they do not weld aluminum unfortunately.
There will be no shaft to support, we are directly mounting to the CIM via a 8mm key hub from AM.
