Go to Post Thats what makes FIRST so unique how culture and the time is reflected through our bots, but at the same time we all get along...with no problem. - Dan Richardson [more]
Unread 01-02-2013, 18:40
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
VEXPro Ball Shifter Shaft Malfunction
Our team has been using the new VEXPro two stage ball shifters for about 2 weeks now on our practice drivetrain. Yesterday while driving, one of the hex output shafts slid out of the gearbox. After some investigation both with the CAD file and disassmbled gearbox we realized the output shaft is just press fit into the gearbox. After reassembly by tapping the shaft in with a hammer and what seemed like a solid fit, we put everything away for the night.
During today's meeting we drove the DT around for a few hours before the shaft came out a second time. We are wondering if anyone else has experienced a similar problem, it seems like our pit crew might have one area to keep a very close eye on this season.
Pictures below for reference.
1058 PVC Pirates 2016 - xxxx
Unread 01-02-2013, 18:47
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Re: VEXPro Ball Shifter Shaft Malfunction
Hi Brendan,
These are a press-fit, but are also cured with loctite. We haven't seen the failure you're describing. You can try using a strong loctite on your shaft, or contact our support department and we'll ship you a replacement. (support@vexrobotics.com or 903.453.0802)
-John
Unread 01-02-2013, 19:04
AKA: Brendan Browne
Originally Posted by JVN View Post
Hi Brendan,
-John
John,
Thank you for the quick reply.
Our students are putting loctite on the shaft and will let it cure overnight and see if that holds.
Thanks!
Brendan
Unread 01-02-2013, 19:52
President, VEX Robotics, Inc.
Please make sure to use loctite 609. We had a few shafts in early production that were not properly cleaned prior to bonding. This may be one of those shafts.
In any case, we will replace it if you can't fix it yourselves.
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
Unread 02-02-2013, 22:27
peronis peronis is offline
Team Leader
FRC #3950 (RoboGym)
peronis is on a distinguished road
We experienced the same thing today when testing our drive base on blocks. One shaft came out and the chains flew off....the other started coming out. Chains were in alignment. The back pair of chains were a little too tight, perhaps that's the reason.
We are thinking about machining a collar to grip the shaft to the shaft housing so our drivetrain will be worry free.
Unread 04-02-2013, 09:24
Vikingtech2054's Avatar
Vikingtech2054 Vikingtech2054 is offline
FRC #5162 (The Big Red Theory)
Vikingtech2054 is an unknown quantity at this point
We experienced the same thing yesterday, we finally got our drive train together and we were just driving around in our schools hallway playing around with the two speed and with in 15 minutes of driving it broke. Our plan is to support it on the end of the shaft to it is supported on both ends while containing it so it can slide out either
Ferris State University-Manufacturing Engineering (BS)
FRC 2054: Student 2010-2013
FTC 6283: Mentor 2012-????
FTC 5980: Mentor 2012-????
FTC 7837: Mentor 2013-????
FRC 2054: Mentor 2013-????
FRC 5162: Mentor 2014-????
FRC 5448: Mentor 2016-????
FRC 5576: Mentor 2015
Unread 04-02-2013, 09:46
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
We also expereinced one of the shafts coming out. For us we noticed before we powered the system and upon investigation noticed that the shaft appeared to have some sort of adhesive on it. So we used the Scotch Adhesive CA8 that came in the KOP. We have not noticed the shaft coming out on this or the other gearboxes we have.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 04-02-2013, 12:17
John and Paul,
Do you have any suggestions for a slipping 36 tooth encoder gear? I added some double sided tape but not sure that is a good fix.
Unread 04-02-2013, 14:49
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
John and Paul,
We had the same problem of the press fit between the output shaft and the encoder gear not being tight enough. We cleaned up the shaft, bearing, and encoder, then added a dab of super glue in the gap between the shaft and the inner bearing race before we pushed the encoder into the bearing. It seems to hold well enough now.
Unread 04-02-2013, 15:44
fox46's Avatar
fox46 fox46 is offline
FRC #2013 (Cybergnomes)
fox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond repute
I am not familiar with these gearboxes but could you remove the components from the box, assemble the two pieces and pin them together with a 1/16" roll pin or hardened dowel? It appears you wouldn't need anything too substantial since all the torque is carried by the hex but a pinned connection would guarantee it wouldn't release. If that stub shaft is driving anything with a side load, the slightest play or flex in the material will almost guarantee that it will eventually wiggle out of its hole. Make sure you use the "green" locktite retaining compound 680 or similar, not the threadlocker types. JB weld could also be a wise choice. I would imagine the brittle nature of superglues (cyanoacrylates) would crack and debond.
Mentor, Team 2013 Cybergnomes 2010 - 2014, 2016
Mentor, Team 3756 RamFerno 2011 - 2013
Mentor, Team 854 Iron Bears 2005-2007
Founding member, Team 854 Iron Bears 2000-2005
Mech.Eng.+Mgt University of Ontario 2009
B.Ed OCT Trent University 2015
Professional Education and Product Knowledge Consultant - Toyota Canada Inc.
Unread 04-02-2013, 15:48
Fox,
The encoder gear presses into a counter bore in one end of the shaft. The gear is delrin or some type of plastic. The counter bore is located in the end of the shaft supported by a bearing. I am inclined to use super glue but I fear the long term effect on the gear as I do not know the exact material it is made from.
Unread 04-02-2013, 16:37
fox46's Avatar
Sorry Al, I was referring to the OP's issue of the output comming loose. Here's an illustration of what I was referring to with a pinned connection to keep the shaft in place-
I think superglue would be a great choice for the encoder issue. There is such little load on that gear anyway.
Unread 04-02-2013, 16:42
AKA: Brendan Browne
Thank you for the suggestion we might try that solution as a precautionary measure after we get a replacement shaft!
Unread 04-02-2013, 16:43
fox46's Avatar
After a second look at that picture, I've noticed if you have that drive sprocket in the picture on the shaft and that nylon spacer is too long, when you tighten the bolt in the end of the shaft it will put a compressive force on that sprocket. The result will be that the bolt in the end of the shaft will be pulling the hex out of the transmission almost like a gear puller. This could certainly break any adhesive bonds and pull the hex stub shaft out of its press fit. Make sure you have the appropriate sized spacers on the end of that hex shaft and leave some space - like 0.010" for the drive gear to slide back and forth to ensure you do not put any tension on the stub shaft and pull it out of the bore.
Unread 04-02-2013, 16:48
That.... is a very astute observation, sir.
Anyone in this thread that's had a hex shaft come out: Are you retaining your sprocket with a bolt at the end of the shaft? Is it possible that you're tightening the bolt so much you're literally pulling the shaft out of that coupler?
