Go to Post your bot brings all the boys to the yard. - looneylin [more]
Unread 04-02-2013, 10:25
Bpk9p4's Avatar
Bpk9p4 Bpk9p4 is offline
FRC #1756
Bpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant future
Labview Open/Create/Replace block
Has anyone used the Open/Create/Replace block in labview to write a file to cRIO. If so how did you go about writing a file to the cRIO
Unread 04-02-2013, 10:36
Re: Labview Open/Create/Replace block
This should work, but I just wrote it up so I won't be able to test it until later.
Usually it's the file path that messes people up on the cRIO.
For the PC you can take the path default, but not for the cRIO.
Unread 04-02-2013, 10:47
Bpk9p4's Avatar
FRC #1756
Thanks we will give that a try. It looks like we were writing to the laptop and not to the cRIO. Do you use this on your teams robot?
