Go to Post It is easy to be righteous on Chief Delphi, and harder to implement in life. - DonRotolo [more]
Unread 03-02-2013, 20:07
IDKnow IDKnow is offline
FRC #1671
IDKnow is an unknown quantity at this point
C++ Network Tables
I am attempting to use the network tables class to pass values from my SmartDashboard extensions to the robot.
This thread describes the process using Java
http://www.chiefdelphi.com/forums/sh...d.php?t=103352
but it seems to imply near the end that the same process will not work for C++
In my code and in the windows API I could find equivalent commands though- for everything other than begin and end transaction.
Without these, the robot crashes as soon an i try TableName->GetNumber("",0);
Am I missing something?
//declarations:
NetworkTable *Vision;
float d;
//initialization
Vision->GetTable("VisionTable");//should create table if does not exist
//control loop (where it crashes)
if (Vision->IsConnected())
     //Vision->beginTransaction();
     d = Vision->GetNumber("d",0);//where 0 is default if "d" does not exist
     //Vision->endTransaction();
Unread 04-02-2013, 08:49
nightpool's Avatar
nightpool nightpool is offline
robotRectifier
AKA: Evan
no team (formerly of CORE 2062)
nightpool is on a distinguished road
Re: C++ Network Tables
Hmm... Normally when interacting with the SmartDashboard one uses the static functions from the SmartDashboard class. Like SmartDashboard::GetNumber("d"), for your example.
As far as I know, the smart dashboard class does not support defaults, because you should initialize variables before you try retrieving them.
Proud alum of CORE 2062.
www.core2062.com
Unread 04-02-2013, 11:07
virtuald's Avatar
virtuald virtuald is online now
RobotPy Guy
AKA: Dustin Spicuzza
If you examine the source code for NetworkTables, you will notice that it throws an exception when you do a GetNumber() without first doing a PutNumber() (only the first PutNumber() is required).
They got rid of Begin/End transaction in this year's implementation of NetworkTables, thus why you can't find it.
Unread 04-02-2013, 21:22
FRC #1671
Thanks guys! You're advice and a little trial and error provided me with the fix:
Putting this before the GetTable command keeps the code from crashing.
I haven't tested getting values yet though because I'm having issues with the SmartDashboard. Also, the put function causes a crash but this is progress! : )
		NetworkTable::SetIPAddress("10.16.71.20");//driverstation IP
		NetworkTable::SetClientMode();
		NetworkTable::SetTeam(1671);
		NetworkTable::Initialize();
Unread 05-02-2013, 00:01
virtuald's Avatar
RobotPy Guy
Keep in mind that the 'client' is the driver station, and the 'server' is the robot. Also, you should only call SetIPAddress or SetTeam, not both. SetTeam is used to determine the IP address of the robot when in client mode. Read the code.
Unread 06-02-2013, 00:49
FRC #1671
http://wpilib.screenstepslive.com/s/...client-pc-side
That's helpful. Still having trouble with the client side but I need to make it work a little differently and I'll get to fixing that tomorrow. Thanks again guys!
