Go to Post After all, professional engineers know The Right Way To Do It (TM) and if we knew that we'd be deprived of the educational experience of screwing up. - phrontist [more]
Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
Unread 21-01-2003, 23:49
com com is offline
#0306 (CRT)
com has a spectacular aura aboutcom has a spectacular aura aboutcom has a spectacular aura about
How good are your tires??
My team and I have been working around the clock to build one of the best drive trains we can. luckly we have finished this new base with some new radical wheels. With these new tires we were able to push one of my mentors around on a steel legged chair on a title floor. We found it very easy to move him around even though our robot only weighted 55 pounds. What do you guys think? Is being able to pull dead weight 4 times your own weight pritty good.
Unread 21-01-2003, 23:53
n[ate]vw's Avatar
n[ate]vw n[ate]vw is offline
#0933 (Adler Attack)
n[ate]vw is an unknown quantity at this point
Send a message via AIM to n[ate]vw
Not necessarily. Our robot last year had beastly rubber wheels that allowed it to drag a large weight around. The wheels actually gave us too much friction and we had trouble with the motors drawing too much current. You need to find the right balance between good traction and allowing the wheels to slip a little to be kind to your motors.
Adler Attack #933 -- Trigos
Unread 21-01-2003, 23:55
jonathan lall's Avatar
jonathan lall jonathan lall is offline
FRC #2505 (The Electric Sheep; FRC #0188 alumnus)
jonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond repute
Send a message via MSN to jonathan lall
Well, that all depends on a number of factors. How well can you steer? How good is your lateral traction? How are you on carpet? I'd be interested to know what you've put together.
Unread 22-01-2003, 00:10
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
RAPTAR has selected some nice tires this year...
They are designed for skid steer (our DT) and pivot well, and maintain good friction for the ramp mesh.
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
Unread 22-01-2003, 09:10
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
I concur with n[ate]vw about traction.
Last year we had awesome traction. We used conveyor belt material on 6" wide, 3" diameter cylinders. Our 35 pound base could pull me (205 lb) across the carpet with me laying on my side on the carpet. One problem though, it wouldn't turn worth a ..... well you know.
So you have to play a balancing game between traction and control.
Good luck this year.
Wayne Doenges
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 22-01-2003, 11:40
DaBruteForceGuy's Avatar
DaBruteForceGuy DaBruteForceGuy is offline
aKa - Steve Bennett
FRC #0125 (NUtrons)
DaBruteForceGuy is an unknown quantity at this point
Send a message via AIM to DaBruteForceGuy
If you think about it, it is quite easy to slide a "mentor" around on a tile (probably lenoleum) floor. We forgo the chair part, and can push pretty much anything around, including mentors, on our slick waxed surface.
Try it on carpet, then you will get a good idea of how much power the drivetrain really has.
Team
810 > 2001-2005 - Student Founder
125 > Present - College Student
---The pessimist complains about the wind, the optimist hopes that the wind will change... the realist adjusts the sail.
***<Therapist> Tell me, is the glass half full or half empty?
***<Engineer> Neither, the glass is too big.---
....Uh, GO NUTRONS!
Unread 22-01-2003, 12:37
com com is offline
#0306 (CRT)
Its not always a trade off for Maneuverability or traction. Often teams solve this with plastic front wheels that will slide sideways. This works but the plastic wheels don't give the best traction. Im not even sure if the plastic wheel idea would hold up to the steel mesh this year. My teams base has extrem maneuverability and probly one of the highest coefficients of friction from the wheels that I have ever seen in my 4 years of robotics. This is all done on the basic 4 wheel drive princiable. Im not telling how we accomplished this but I will give a hint, im sure some of you will figure it out, 'battle bots do this a lot with there drive train'.
Robots and brakeable objects don't mix, Oh and don't let the little 9th graders that don't know what there doing put a medal ruler in your chain and sprocket setup. ARGGGGG what I have to put up with
Unread 22-01-2003, 12:47
com com is offline
#0306 (CRT)
probably lenoleum floor...
Yes it is,
Lets just say, the floor is old and needs a good wax job.
Steel on lenoleum reminds me of glass on glass, both smooth but bind very well.
Unread 22-01-2003, 13:16
galewind's Avatar
galewind galewind is offline
... more like a temperate breeze
AKA: Chris Gregory
FRC #1089 (Team Mercury)
galewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond repute
Send a message via AIM to galewind
tires with air?
We're toying with the possibility of using modified tires that are from a handtruck that will have a significant footprint for better traction (tubeless). We're intending on keeping the wheels fairly shielded. Is having an air-filled tire bad news? Does anyone else use non-solid tires?
It's understood that we'll want to keep a few extra on-hand, but i'm not sure exactly how many of these we should expect to go through. I know those tires are designed to take on a significant amount of weight, which shouldn't be a problem with 4.
All ideas appreciated.
Chris G
Advisor, Team Mercury (1089), Hightstown High School
Unread 22-01-2003, 14:36
aKa - Steve Bennett
FRC #0125 (NUtrons)
Re: tires with air?
Yea, pneumatic tires are a great concept, but they are a lil much (if u know what i am getting at). If u look at the reason they were invented, they are made to absorb irregular sufaces on the riding suface. We really don't deal with complications liek that on the rock hard, flat carpet surface. We have all concidered them in the past, but it just turns out to be overkill, the foam insides or softer rubber should be sufficient for the rap curbs and such when it comes to impact and shock absorbtion.
Team
....Uh, GO NUTRONS!
Unread 22-01-2003, 15:44
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Re: tires with air?
Pneumatic tires will potentially have a huge advantage on the mesh...anything that can conform to the surface in any manner will
Pneumatic tires are great. we used them last year, and one set lasted through three competitions just fine...ours were very vulnerable, and we never has any issues with stabbing/popping.
P.S. I'd say that wire mesh is an irregular surface
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 22-01-2003, 15:52
aKa - Steve Bennett
FRC #0125 (NUtrons)
Re: Re: Re: tires with air?
Cory
DOPE!!*stabbs self with pencil*-- your right....
I forgot about that..... But i guess that just because we havn't given the ramp much thought....
Team
....Uh, GO NUTRONS!
Unread 22-01-2003, 16:09
Gope Gope is offline
#0016 (Bomb Squad)
Gope is on a distinguished road
Last year, in low speed, our robot could pull it's weight(130) with a goal (120 i think) with a 160lb engineer laying flat on the carpet floor holding the goal(talk about traction). And the thing is, we weren't even among the strongest robot at nationals.
So, don't expect to be the strongest anywhere you go.
College and its wonders. First year and alot of other FIRSTs.
Unread 22-01-2003, 16:23
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
BAH traction is not a problem...
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 22-01-2003, 20:46
Mike Norton's Avatar
Mike Norton Mike Norton is offline
FRC #0061
Rookie Year: 1995
Mike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to all
Some teams out here have been working on traction for a long time. If you think you have a strong robot just look at the teams that put everything into their traction and motor train.
We were good in strong last year but was as strong as are track could hold. The Breco flex tracks do rip apart under high loads.
I think the best way of getting the most traction is by a track system. but it will take years of proving different design to come up with one that works.
Traction is good but a good driver will always win over a good robot.
Vanilla Coke..good? bad? A. Leese Chit-Chat 41 07-01-2004 00:15
Do u thinks its a good idea to start 2004 anim? Salik Syed 3D Animation and Competition 22 31-03-2003 00:48
What makes the Good, So good? Chris General Forum 16 18-07-2002 11:09
Patriots say good bye DREW!! 157#1Driver Chit-Chat 4 22-04-2002 12:26
Good luck to all at Nats Ben Mitchell Chit-Chat 0 18-04-2002 19:59
