Go to Post Never leave future engineers alone, especially with something like gravity. - Alex Pelan [more]
Unread 04-02-2013, 08:10
Chadfrom308's Avatar
Chadfrom308 Chadfrom308 is offline
Slave to the bot
AKA: Chad Krause
FRC #0308 (The Monsters)
Team Role: Driver
Chadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to behold
How to project an image with standard LEDs
So our team is making a new robot cart this year since the old one is basically 3in pvc and some wheels. We were thinking of making it semi powered with some lights that project the 308 logo. Our idea is to make it red, green, or white. This idea came from the 2013 Mustang's puddle light. Anybody have any thoughts on how we can do this? my Idea is like a box with the logo cut out on one side and the light set back a couple of inches in the box, kind of like a projector.
Our mentor has a '13 Mustang and there is no shape cut out or anything, just a hole
Note: this is not our picture
Unread 04-02-2013, 09:51
lorem3k's Avatar
lorem3k lorem3k is offline
1 + 1 = 0 (in Z/2Z)
AKA: Andy D.
FRC #1482 (Bishop Grandin Ghosts)
lorem3k is a splendid one to beholdlorem3k is a splendid one to beholdlorem3k is a splendid one to beholdlorem3k is a splendid one to beholdlorem3k is a splendid one to beholdlorem3k is a splendid one to behold
Re: How to project an image with standard LEDs
The shape on the Mustang is probably cut somewhere inside the LED itself.
Boo! Bishop Grandin High School / GM Canada / Tenaris
2013 Western Canada - Quarterfinalists (thanks 288/4719) / 2012 GTR West - Quarterfinalists (thanks 188/1075) / 2011 GTR East - Regional Winners (thanks 1114/1503)
Unread 04-02-2013, 11:48
neshera's Avatar
neshera neshera is offline
Nesher G. Asner
AKA: Nesher G. Asner
FRC #1625 (Winnovation)
Team Role: Parent
neshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud of
If you use an LED light box and a stencil, remember the greater the distance between the LED and the stencil, the sharper the shadow.
Do not panic! All is well!
- Kevin Bacon in Animal House
Unread 04-02-2013, 14:18
Image projectors like this typically have a "stencil" at the focal plane of a lens system. It's like a slide projector. You can do it with a bright enough point source of light and no lenses, but it's going to be brighter using an optical path that actually focuses the light where you want it.
Unread 05-02-2013, 20:19
DonRotolo's Avatar
Back to humble
FRC #0832
Yes indeed, you need a lens in there somewhere to "project" the stencil image. Just LEDs and a stencil will give poor results.
Try it with a simple lens, like that in a magnifying glass. Cut a shape out of cardboard, and EXPERIMENT with a light source/lens/cutout combination. Often Light > Stencil > Lens works best. Different distances between those elements give different results.
Eventually you might try different lenses to see what works best.
Unread 05-02-2013, 20:51
rl1806's Avatar
rl1806 rl1806 is offline
AKA: Ryan Lowe
FRC #1806 (S.W.A.T.)
rl1806 will become famous soon enough
That is a small version of a GOBO (Goes Before Optics) system. http://en.wikipedia.org/wiki/Gobo_(lighting)
The system uses a light source that passes through a stencil then a lens to project the final image. FIRST uses these at various regionals and championships to project the FIRST logo. If you wanted to you could make multiple stencils and switch them to have different designs.
2011-Present: SWAT FRC 1806 Mentor
2012 Rockwell Automation Innovation in Control Award [Oklahoma City]
Unread 05-02-2013, 21:04
BrendanRadabaug's Avatar
BrendanRadabaug BrendanRadabaug is offline
FRC #1902 (Exploding Bacon)
BrendanRadabaug is a splendid one to beholdBrendanRadabaug is a splendid one to beholdBrendanRadabaug is a splendid one to beholdBrendanRadabaug is a splendid one to beholdBrendanRadabaug is a splendid one to beholdBrendanRadabaug is a splendid one to behold
we have this for our pit area and sponsor events, its a stand alone spotlight with a metal disk insert with the shape cut out. then mirrors for sharpness. it could be done small scale but the cutting of the disk would be troublesome.
Bacon
Unread 05-02-2013, 21:28
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
the "bacon beacon" is one of these LED gobo projectors:
http://www.chauvetlighting.com/lfs-5.html
with a custom gobo (ordered through my work) made by this company:
http://apollodesign.net/
There is a company who makes tiny gobo projectors called darklight:
http://www.darklightsystem.com/led-l...age-projector/
I'm not associated with the sites below, the first 3 I deal with in my day job.
also you can get little custom flashlights you drop a gobo in:
http://www.youtube.com/watch?v=kN062j11cBY
and the ones for cars (probably what your looking for) I found here:
http://www.gtrlighting.com/led-light...athway-21.html
This is the first time I have seen those door projectors, pretty cool idea if you can make it happen!
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
Unread 12-02-2013, 07:25
Slave to the bot
AKA: Chad Krause
Team Role: Driver
Thanks, we are going to look this over and see what the team thinks! thanks!
