Go to Post I know the code works, I wrote it! It must be a hardware problem. - buss [more]
Unread 04-02-2013, 15:54
eyeswideopened eyeswideopened is offline
FRC #4557
eyeswideopened is an unknown quantity at this point
Lift Motor Button Help
I need some help with controling the lift motors for the robot. The team wants to use buttons 6 and 7 on the joystick. Button 6 makes the lift arms retract thus lifting the robot and button 7 makes the arms exend thus lowering the robot. How do I write the code that while button 6 is being held down the Arms willl retract and simmilarly for button 7.
I am not very experienced with Labview, if you could offer any help that would be much appreciated. Thank you in advance!
Unread 04-02-2013, 16:27
Re: Lift Motor Button Help
Use the Chief Delphi search feature. Look for "motor button" and you'll find plenty of answers have already been given. This one seems like it'll help you.
