Go to Post "It's not a flashlight! it's an arduino with a really strong status LED!" - Leav [more]
Unread 04-02-2013, 16:48
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: VEXPro Ball Shifter Shaft Malfunction
Originally Posted by fox46 View Post
After a second look at that picture, I've noticed if you have that drive sprocket in the picture on the shaft and that nylon spacer is too long, when you tighten the bolt in the end of the shaft it will put a compressive force on that sprocket. The result will be that the bolt in the end of the shaft will be pulling the hex out of the transmission almost like a gear puller. This could certainly break any adhesive bonds and pull the hex stub shaft out of its press fit. Make sure you have the appropriate sized spacers on the end of that hex shaft and leave some space - like 0.010" for the drive gear to slide back and forth to ensure you do not put any tension on the stub shaft and pull it out of the bore.
That.... is a very astute observation, sir.
Anyone in this thread that's had a hex shaft come out: Are you retaining your sprocket with a bolt at the end of the shaft? Is it possible that you're tightening the bolt so much you're literally pulling the shaft out of that coupler?
