Go to Post I'm not suffering from my FIRST "addiction". I enjoy every minute of it. - Katie_UPS [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 04-02-2013, 16:42
RandomStyuff RandomStyuff is offline
FRC #2212 (Spikes)
RandomStyuff is a jewel in the roughRandomStyuff is a jewel in the roughRandomStyuff is a jewel in the roughRandomStyuff is a jewel in the rough
Mixing grease types
Hi
In my team's kit toughbox mini gearboxes we used the kit included silicone grease. Because we took the gearboxes apart a number of times, to debug an issue we had, we feel we might not have enough grease in the gearbox. We also have a can of White Lithium grease that arrived after we started assembly of the robot.
We were thinking of adding some of the white lithium grease to the gearbox without washing the silicone grease out, because taking the gearbox apart is quite a significant process with our design right now.
Is it ok to mix grease types together in the same gearbox in an FRC environment? I'm told that in real world engineering it's disliked, but I haven't been able to get an answer when it comes to the load types that are found in an FRC robot's drive system.
Thanks in Advance.
Because using your robot's cannon to shoot at your nation's Minister of Education is worth all the 6 weeks of no sleep!
Unread 04-02-2013, 16:48
WileyB-J's Avatar
WileyB-J WileyB-J is offline
4976 Georgetown Rebels
FRC #4976 (Rebels)
WileyB-J will become famous soon enoughWileyB-J will become famous soon enough
Re: Mixing grease types
It depends on if the greases are compatible really..
But in all things necessary; you will be fine.
Just use more of the grease you plan on sticking with and do your best to open it up sometime during the comp. season to apply more grease.
Unread 04-02-2013, 17:24
JDL JDL is offline
Systems Integrator
FRC #0498
JDL is just really niceJDL is just really niceJDL is just really niceJDL is just really nice
Clean the old stuff out quick with industrial cleaner/degreaser and start fresh.
Unread 04-02-2013, 17:30
fox46's Avatar
fox46 fox46 is offline
FRC #2013 (Cybergnomes)
fox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond repute
As you mentioned, the proper thing to do is to dissassemble the boxes and wash all the old stuff off with mineral spirits or non-chlorinated brake cleaner and then apply your grease of choice. However in the case of the toughboxes, given their light duty you will probably be fine mixing the two. You really don't need much grease on those gears so don't go packing them full of the stuff. Too much grease will cause losses as the gears have to "pump" the stuff around inside. Generally a light coating is all you really need. I would bet your initial application of silicone grease is still plenty sufficient and that you likely don't need to apply any more. I would be far more concerned about bits of grit and dirt in there from the multiple rebuilds without cleaning. Grease makes a great glue for sticking debris to gears.
http://www.machinerylubrication.com/...mixing-greases
Mentor, Team 2013 Cybergnomes 2010 - 2014, 2016
Mentor, Team 3756 RamFerno 2011 - 2013
Mentor, Team 854 Iron Bears 2005-2007
Founding member, Team 854 Iron Bears 2000-2005
Mech.Eng.+Mgt University of Ontario 2009
B.Ed OCT Trent University 2015
Professional Education and Product Knowledge Consultant - Toyota Canada Inc.
