Go to Post Why aren't the kids who sit alongside the sidelines and observe as valued? Why are they looked upon as leeches, in it for a trip? - Madison [more]
Unread 04-02-2013, 16:50
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Re: VEXPro Ball Shifter Shaft Malfunction
Originally Posted by Kevin Sevcik View Post
That.... is a very astute observation, sir.
Anyone in this thread that's had a hex shaft come out: Are you retaining your sprocket with a bolt at the end of the shaft? Is it possible that you're tightening the bolt so much you're literally pulling the shaft out of that coupler?
I will check tonight when I can get a close look at the transmission. It is possible but IIRC after inspecting the completed drivetrains those hex sprockets had a little bit of play in them.
Very good observation though!
1058 PVC Pirates 2016 - xxxx
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is online now
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
We are using the timing belt pulley's which were far enough from the end of the shaft that the bolt tightened into the end of the shaft with some slop left on the pulley.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 02-04-2013, 19:58
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
Has anybody intentionally removed these press-fit shafts in order to install longer hex shafts?
Unread 02-04-2013, 22:22
tribologist tribologist is offline
FRC #0177
tribologist is on a distinguished road
It is very easy to remove. The anodization, left over schmutz and grease makes it a week bond. Clamp the shaft in a vise and tap it off with a brass drift (or that screw driver you don't like).
When you make the new shaft you need to drill out a hole at the end so that the spool is not blocked. Measure the hole on the old shaft.
Use Loctite 603 and be very careful to clean everything before bonding. You are best off lubricating after assembly.
Ulf
Unread 03-04-2013, 12:26
Mentor,QCR Planning
Originally Posted by BrendanB View Post
Thank you for the suggestion we might try that solution as a precautionary measure after we get a replacement shaft!
That is what we did after the 4 we had failed. The new ones that were shipped were drilled and pinned before ever seeing the robot and drive time. We have not had any issues since.
Unread 03-04-2013, 13:47
fox46's Avatar
fox46 fox46 is offline
FRC #2013 (Cybergnomes)
fox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond repute
Good to hear!
Mentor, Team 2013 Cybergnomes 2010 - 2014, 2016
Mentor, Team 3756 RamFerno 2011 - 2013
Mentor, Team 854 Iron Bears 2005-2007
Founding member, Team 854 Iron Bears 2000-2005
Mech.Eng.+Mgt University of Ontario 2009
B.Ed OCT Trent University 2015
Professional Education and Product Knowledge Consultant - Toyota Canada Inc.
