Go to Post I would hate for you to get the impression that the Northeast is one big unending snowglobe during the winter months. - Elgin Clock [more]
Unread 04-02-2013, 17:40
dcorneail's Avatar
dcorneail dcorneail is offline
FRC #1684 (Magic Smoke)
dcorneail is an unknown quantity at this point
can you run 2 pistons of one solenoid legally?
i would preferably like to use as little solenoids as possible this year and would like to know if you can run multiple pistons of solenoids
Unread 04-02-2013, 17:59
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: can you run 2 pistons of one solenoid legally?
Sure, there's no rule against it, just a rule against using multiple solenoid valves to drive one cylinder.
Unread 04-02-2013, 18:14
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Yes but you will decease the air flow to the two cylinders in half. That may not matter for smaller cylinders but it will make larger ones slow.
Unread 06-02-2013, 12:33
Curt Henderson's Avatar
Curt Henderson Curt Henderson is offline
FRC #1501 (Team T.H.R.U.S.T)
Curt Henderson is a jewel in the roughCurt Henderson is a jewel in the roughCurt Henderson is a jewel in the rough
Send a message via Yahoo to Curt Henderson
Another issue to consider is that the cylinders will extend and retract in a staggard pattern due to only one cylinder moving at a time due to imbalance if the air pressure in the system which will move the cylinder with the least amount of resistance first. If they are hooked to a rigid enough structure that affect will be minimal, but in a flexible(less rigid) structure it could get bound up and not move after the first cylinder extends.
