Go to Post and don't overestimate the ability of an unskilled fool with exotic tools! - MissInformation [more]
Unread 04-02-2013, 17:56
lunamoonthroat lunamoonthroat is offline
FRC #4137
lunamoonthroat is an unknown quantity at this point
Multiple Cameras?
Hey All you FIRST'ers!
We're trying to run two cameras on our robot for ranging, but the AxisCamera is a singleton class (we're using java), and our custom code (overriding the actual AxisCamera doesn't seem to interface for creating multiple cameras. Any ideas? Regards,
Unread 04-02-2013, 18:39
flamer075 flamer075 is offline
FRC #3200
flamer075 is an unknown quantity at this point
Re: Multiple Cameras?
Hey, my team decided that we wanted 2 cameras going with a dual live feed last year. We also coded in java, but for getting two cameras at once I would recommend using a smart dashboard or using labview and modifying it so you can get two live feeds at once. If you don't mind why would you want to use two cameras for this game.
Unread 04-02-2013, 18:40
Kusha's Avatar
Kusha Kusha is offline
Crimpin' ain't easy
AKA: Kusha Gharahi
no team (Looking for a team)
Kusha is a jewel in the roughKusha is a jewel in the roughKusha is a jewel in the roughKusha is a jewel in the rough
Why did you use duel cameras last year? If you don't mind me asking.
https://kusha.me
Unread 04-02-2013, 18:53
xraymypanda's Avatar
xraymypanda xraymypanda is offline
Cowboy programmer
AKA: Chris M
FRC #0599 (RoboDox)
xraymypanda has a spectacular aura aboutxraymypanda has a spectacular aura about
With regards to the set up of two cameras:www.chiefdelphi.com/media/papers/2634
However, beware exceeding your bandwidth limit.
2011: Head Scout
2012: (figure)Head Programmer
2013: Head Programmer, Chief Strategist, Outreach Executive, and Driver
Unread 05-02-2013, 07:34
FRC #4137
Thanks @xraymypanda! However, I already looked at that document, and it may be helpful for C++ and LabView, but for the Java bindings, it is unfortunately mute. Because the Java binding is somehow a singleton due to the way it is ported, after AxisCamera.getInstance(ip1) is called, AxisCamera.getInstance(ip2) returns a reference to ip1 instead.
@flamer075: We are trying to get more accurate ranging measurements from stereoscopic vision.
Unread 05-02-2013, 08:22
mathking's Avatar
mathking mathking is offline
Coach/Faculty Advisor
AKA: Greg King
FRC #1014 (Dublin Robotics aka "Bad Robots")
mathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond repute
We used two cameras in Java last year using Smartdashboard. We did it because one was for targeting and the other (added after the regional for the championships) was looking down for ball gathering purposes. Others have said it but beware of bandwidth issues. If you want some technical help let me know and I will put one of our programmers in touch with you. Actually I think that some two camera code is already posted on our github repository.
Thank you Bad Robots for giving me the chance to coach this team.
Rookie All-Star Award: 2003 Buckeye
Engineering Inspiration Award: 2004 Pittsburgh, 2014 Crossroads
Chairman's Award: 2005 Pittsburgh, 2009 Buckeye, 2012 Queen City
Team Spirit Award: 2007 Buckeye, 2015 Queen City
Woodie Flowers Award: 2009 Buckeye
Dean's List Finalists: Phil Aufdencamp (2010), Lindsey Fox (2011), Kyle Torrico (2011), Alix Bernier (2013), Deepthi Thumuluri (2015)
Gracious Professionalism Award: 2013 Buckeye
Innovation in Controls Award: 2015 Pittsburgh
Event Finalists: 2012 CORI, 2016 Buckeye
Unread 05-02-2013, 08:32
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Like Greg we used two cameras last year, one mounted high with the shooter and the other down low with the ball pickup mostly used to see under the bridge.
We didn't need high resolution for either task so we set the resolution very low and never had any trouble
Unread 05-02-2013, 09:21
JohnFogarty's Avatar
AKA: @doctorfogarty
I used two cameras as well. SmartDashboard is by far the easiest thing to use.
Make sure you set the less needed camera to a lower resolution so you don't max out your bandwidth.
John Fogarty
Unread 05-02-2013, 10:55
FRC #4137
By SmartDashboard, do you mean connecting both cameras to the dashboard, then getting images from the dashboard instead of the camera directly?
