Go to Post Crushing the box makes it much easier to think outside the box. :D - Matt C [more]
Unread 04-02-2013, 08:51
Bryce Paputa's Avatar
Happy Birthday! Bryce Paputa Bryce Paputa is offline
FF TSL: Frog Farce
FRC #0503 (Frog Force)
Bryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond repute
pic: Frog Force 503 Drivetrain & Chassis Size Comparison
Unread 04-02-2013, 08:52
thmeans06 thmeans06 is offline
Drive Coach, IT Support, Mentor
FRC #0066
thmeans06 is an unknown quantity at this point
Re: pic: Frog Force 503 Drivetrain & Chassis Size Comparison
Have you used 1/16th" before? We have thought about it but have always been afraid of it getting bent from a hard hit. If it works well for you we may have to try it in the future.
Unread 04-02-2013, 15:14
Zebra_Fact_Man's Avatar
Zebra_Fact_Man Zebra_Fact_Man is offline
]\/[ Go Blue!
AKA: Solomon
FRC #1076 (Pi Hi Samurai)
Zebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant future
From my experience, with the mandatory bumper rules implored nowadays, 1/16" is more than strong enough. It was only back in the day with frame-on-frame contact did you NEED 1/8" aluminum.
Unread 04-02-2013, 15:40
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
Even back then we used 0.063 sheet for drivetrains and it held up fine. With bumpers we've gone down to 0.050. Folded sheet metal structures get their strength from how they are jointed much more so then from their thickness.
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Unread 04-02-2013, 19:03
TheMadCADer TheMadCADer is offline
TheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant future
You make a great point. So much of engineering is finding better geometries for parts so that you can use less to get more.
My favorite examples of this principle are actually from the late 1800s, at the Paris and Chicago World's Fairs, the where the Eiffel Tower and original Ferris Wheel were respectively unveiled. Both were somewhat controversial when proposed, as many refused to believe that structures made of such thin members could support themselves. Initially, many people refused to ride the Ferris Wheel, because they thought it would collapse at any moment. The Eiffel Tower, if made into a solid block the size of its base, would only stand 6 cm tall.
Another good example is a soda can. You can support the weight of most average people on top of a sheet of aluminum about as thin as paper.
Unread 05-02-2013, 00:53
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
How are your wheels mounted, it looks like dead axels with custom (plastic?, 3D printed?) pieces that are able to slide in the slots. Am I on the right track?
Unread 05-02-2013, 09:05
BJC's Avatar
BJC BJC is offline
AKA: Bryan Culver
It looks to me that they are using the same method that 67 uses. If that's the case then that is a tapped 1/4" aluminum plate which supports a dead axle in shear and can be slid to tension its respective wheel.
Unread 05-02-2013, 10:43
Adam Freeman's Avatar
Adam Freeman Adam Freeman is offline
Forever HOT!
FRC #0148 (Robowranglers)
Adam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond repute
Bryan is a very good observer. 503 actually met with us over the summer to review our chassis / drivetrain strategy.
It looks like they took some pretty good notes. This chassis looks very similar to the sheet metal chassis we have produced in the past. Though, we typically have sometype of mid panel designed in for additional support.
I believe they water-jet aluminum axle blocks for the wheels. We typically use 0.25" rectangular blocks with capture nuts to secure the blocks to the frame. 1/2" axles are typically bolted to the blocks with a flat head 1/4-20 bolt.
2005 FIRST World Champions (330, 67, 503)
2009 FIRST World Champions (111, 67, 971)
2010 FIRST World Champions (294, 67, 177)
