Go to Post Starting projects is fun, easy, and exposes you to new things, but finishing them shows true character. - Greg McKaskle [more]
Unread 04-02-2013, 19:18
Landonh12's Avatar
Landonh12 Landonh12 is online now
270 points
AKA: Landon Haugh
FRC #0364 (Team Fusion)
Landonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud of
Cypress PSoC 3 driver problems
We plan on using our control board from last year. I have installed everything that comes on the CD for the PSoC 3 board, and I have installed the PSoC programmer 3.17 right from Cypress's website. When I open up device manager, I get an Unknown Device message.
I am currently running this on Windows 8, so that may be the problem.
If anyone has any idea of how to get Windows to recognize the board so that I can set up the Configuration in the Driver Station and start programming this thing in LabView, thank you. I'll provide any information as needed.
-Landon, Team Fusion 364 Programming
Unread 04-02-2013, 19:42
Re: Cypress PSoC 3 driver problems
You probably have the wrong version. See http://wpilib.screenstepslive.com/s/...module-for-frc
Unread 04-02-2013, 19:48
Landonh12's Avatar
270 points
AKA: Landon Haugh
I have been successful with the board on other computers that were configured correctly. I also programmed it to do certain fuctions with a proto bot.
I'm sure that the firmware is loaded correctly and that this is most likely a computer issue.
Edit: I have gotten the drivers installed. I will upload firmware asap just to make sure that it is up to date.
Now that I have gotten the drivers installed on our laptop, I tried testing the board in the driver station. It isn't working.
I went to the old computer that it worked on and it isn't working on that one now. I'll see tomorrow what i can get working.
