Go to Post Who needs weapons when you have a scary face - Conor Ryan [more]
Unread 04-02-2013, 20:08
MrTechCenter's Avatar
MrTechCenter MrTechCenter is offline
INTENSITY
AKA: Harsharan "Harsh" Dhaliwal
FRC #2073 (Eagleforce)
MrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant future
One side of drivetrain not working properly
For some reason, whenever we enable our robot, the left side of our drivetrain runs at full power. We can still override it with a joystick...to an extent. When the joystick value returns to "0" the motors continue to run. We are using VexPro ball shifters with two CIMs per side all being controlled by four Victor 888s. The Victors are connected to the Digital Sidecar via two PWM-Y cables, one for each side. We are using LabView 2013 for programming.
2011 Sacramento Regional Finalists; 2011 MadTown Throwdown VIP Excellence in Engineering Award; 2012 Sacramento Regional Innovation in Control Award; 2012 Silicon Valley Regional Judges' Award; 2012 CalGames Autonomous Challenge Award; 2012 MadTown Throwdown Finalists; 2013 P0W3RH0U53 PWNAGE Gracios Professionalism Award; 2014 Central Valley Regional Innovation in Control; 2014 Sacramento Regional Innovation in Control; 2014 Curie Division Gracious Professionalism Award; 2015 Sacramento Regional Innovation in Control
Unread 04-02-2013, 20:15
BitTwiddler's Avatar
BitTwiddler BitTwiddler is offline
electronics/programming mentor
AKA: Mr Tanguay
FRC #1726 (N.E.R.D.S.)
BitTwiddler is on a distinguished road
Re: One side of drivetrain not working properly
What happens if you disconnect the PWM cable for the left side?
Unread 04-02-2013, 20:18
INTENSITY
The left side doesn't run.
Unread 04-02-2013, 20:21
Kusha's Avatar
Kusha Kusha is offline
Crimpin' ain't easy
AKA: Kusha Gharahi
no team (Looking for a team)
Kusha is a jewel in the roughKusha is a jewel in the roughKusha is a jewel in the roughKusha is a jewel in the rough
Try replacing the ribbon cable from the c-rio to the sidecar.
https://kusha.me
Unread 04-02-2013, 20:29
INTENSITY
Replacing the ribbon cable did not help.
Unread 04-02-2013, 20:31
AKA: Mr Tanguay
OK, something is commanding the motor controller to go forward (or reverse as the case may be). i.e. you are getting a pulse width <> 1.5 ms.
Unread 04-02-2013, 20:37
INTENSITY
It is definitely a code problem, because with a brand new cRIO project, it worked fine.
Unread 04-02-2013, 20:40
AKA: Mr Tanguay
[quote=MrTechCenter;(30 minutes later after looking through every inch of the code): I found the problem! PWM was backwards./QUOTE]
It's amazing the way those pesky cables manage to turn themselves around, isn't it?
Unread 04-02-2013, 20:50
INTENSITY
All PWMs are plugged-in correctly and into the right ports on the Digital Sidecar. It worked properly when we tried it once and we didn't change anything after that on the robot or the code except for accidentally breaking a single wire in the code and replacing it, and we made sure that everything else was exactly the same, and no other wires in code were broken. But for some reason, it's not working again.
Unread 04-02-2013, 22:08
AKA: Mr Tanguay
Agreed. I think it is the code.
I bet it will run fine with another try with a new project using the default FRC code.
Unread 04-02-2013, 22:16
If you want to zip up the entire project and attach it, we can take a look.
Unread 04-02-2013, 22:22
Team3266Spencer's Avatar
Team3266Spencer Team3266Spencer is offline
Team Captain and Lead Programmer
AKA: Spencer Lanman
FRC #3266 (Robots-R-US)
Team3266Spencer is an unknown quantity at this point
Did you try re-calibrating the victors?
2012: Buckeye Regional, Queen City Regional, Human Player
2013: Queen City Regional, Buckeye Regional, Crossroads Regional
Shooter Operator
2014: Crossroads Regional, Queen City Regional
Catapult Operator
2015: Georgia Southern Classic Regional (Winner), Queen City Regional
Chainsaw Operator
Want to talk? TeamSpeak: team3266.noip.me
Unread 04-02-2013, 22:56
INTENSITY
The coding laptop is at our shop, so I can't upload the project as of right now. We have not yet re-calibrated the Victors. Tomorrow, we are going to just start our code over from scratch and see if the problem reoccurs.
Unread 04-02-2013, 23:28
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Unplug the joysticks and plug them back in.
When you plug in a joystick, it re-calibrates itself to zero where it is when you plug it in. If you leave a gamepad upside down and plug it in, and it is resting on the stick, then when you pick it up and it spring returns to center it will have learned an incorrect zero point and will now be holding a nonzero value at what should be zero.
In LabVIEW, if you hit the Run button in code and wait for it to deploy, you can click on a wire to view the value of that wire in a probe watch window. That can be helpful for finding where numbers come from in more complex code.
Kettering Motorsports
