Go to Post "So Ken Patton, Paul Copioli, and John V-Neun walk into a bar..." - JVN [more]
Unread 04-02-2013, 21:12
thvs thvs is offline
FRC #4704
thvs is an unknown quantity at this point
Victor motor contorls flashing orange
Hi,
Our victor lights are flashing orange. We have changed the victors and the PWM cables and ensured that everything is wired properly. We were thinking that maybe there was something wrong with the sidecar or the program (labview) that caused the victors to flash orange. The robot was running fine a couple of weeks ago, but we rewired everything, and now it won't run.
What colors should the lights be when running properly?
Can we test to see if there is something wrong with the sidecar?
Is there anything we should be watching for when programming in labview regarding the victors?
Is there any reason, other then no PWM signal, for the light to be flashing orange?
Thanks
Unread 04-02-2013, 21:20
Johnbot's Avatar
Johnbot Johnbot is offline
Es Brokein!
AKA: John Westhoff
FRC #4791 (Pandroids)
Johnbot is just really niceJohnbot is just really niceJohnbot is just really niceJohnbot is just really niceJohnbot is just really nice
Re: Victor motor contorls flashing orange
According to the datasheets for both the Victor 888 and Victor 884, the Orange flashing LED represents no PWM, and only no PWM. You should check the direction of the PWM and the slot it is plugged into as well as which slot the code wants it plugged into. Also, you should make sure that the sidecar is fully functional with the power LEDs all green, and make sure that the ribbon cable is fully inserted on both ends.
Edit: From the datasheet:
LED Indicator Status
• Green = Full Forward
• Orange = Neutral/Brake
• Red = Full Reverse
• Flashing Orange = no PWM
2011-2014 - FRC 2607 - Student
2012-2012 - FLL 2249 - Coach
2015- ???? - FRC 4791 - Mentor
Unread 04-02-2013, 21:39
FRC #4704
Hi,
We have checked and everything seems to be in place. When we calibrate the controls they flash green for 2 seconds, then go back to flashing orange. I don't know if that means anything, but I was thinking that meant that there was nothing wrong with the wiring.
Also we got our robot to move by disabling the safety config in the program for the motor controls, However; I don't think that's the right answer.
Unread 04-02-2013, 22:37
BitTwiddler's Avatar
BitTwiddler BitTwiddler is offline
electronics/programming mentor
AKA: Mr Tanguay
FRC #1726 (N.E.R.D.S.)
BitTwiddler is on a distinguished road
Originally Posted by thvs View Post
Hi,
That tells me the problem is in the code somewhere. Are you using LabVIEW? Are you periodically setting the motor value (i.e. every 100 ms or so)?
Unread 05-02-2013, 00:15
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
It seems like your program isn't updating the motor values when it's at zero. If you are able to calibrate but than it goes back to flashing orange that probably means motorsafety is killing the outputs for some reason.
If you only update the motor values if the joystick value changes, that might result in this type of problem.
Are you establishing all of them as Victors and not as Jaguars in code?
Unread 05-02-2013, 10:25
FRC #4704
We are using labview. I don't now if we are setting the motor values, how would you check that?
Unread 05-02-2013, 10:34
FRC #4704
If the problem is with updating motor values, what needs to be changed in the program?
They are established as victors.
Unread 05-02-2013, 10:41
Tem1514 Mentor's Avatar
Tem1514 Mentor Tem1514 Mentor is offline
FRC #1514
Tem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to behold
Hi Tina,
If I recall you are the rookie team that we helped get going at the 610 quick build?
If that's the case my email to you should help. At the present, I really think that either the PWM cable(s) have been unplugged and or you have not enabled the robot.
I hope the email helps.
BTW.
This is a wonderful place to get help, Chief Delphi that is.
Unread 05-02-2013, 10:54
FRC #4704
Originally Posted by Tem1514 Mentor View Post
Hi Tina,
BTW.
Hi,
We did receive the email, and checked all of the components you stated but the light is still flashing so we are inclined to believe its a programming error. We even had a mechanic and an electrician look at our robot and neither of them could see an error in the wiring.
Do you know of anything we should look for in the program
Thanks
Unread 05-02-2013, 11:00
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Can you post screen-shots of your Begin.vi Teleop.vi and Finish.vi?
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 05-02-2013, 11:10
Everything A lot of what you describe is consistent with an improper PWM cable connection. It takes practice to be able to insert a PWM connector into a Victor properly every time. Unplug one and inspect the pins. They should be perfectly straight. If any are bent, it's likely that it wasn't making proper contact.
Unread 05-02-2013, 11:25
rfolea's Avatar
rfolea rfolea is offline
AKA: Rick Folea
no team (Forsyth Alliance)
rfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant future
Is the dashboard installed, operating and enabled?
LEDs will flash orange until the robot is enabled ... right?
Unread 05-02-2013, 11:37
FRC #4704
We have been using the basic code, except in the begin VI we changed the safety config to disabled and the Jaguar to a Victor.
Unread 05-02-2013, 11:41
FRC #4704
It is Flashing orange unless the robot is moving, then there is no color.
Unread 05-02-2013, 11:44
Now that sounds like a Victor calibration/joystick centering issue.
The orange flickering light might mean that neutral on the joystick is right at the edge of the Victor's neutral dead zone.
That's not a dangerous condition, just annoying.
With the robot up on blocks can you push the joystick to it's extreme's and see the Victor status light turn green in one direction and red in the opposite direction?
