Go to Post bedtime? there's no bedtime while chief delphi is up and running! - Alex Cormier [more]
Unread 04-02-2013, 22:09
team3039 team3039 is offline
FRC #3039
team3039 is an unknown quantity at this point
No battery voltage readings on DS!
We've tried to replace the analog breakout board on the cRio, and the jumper is hooked up to the two outer pins. Still no battery voltage readings on the DS. Does anyone know what's wrong?
Unread 04-02-2013, 22:17
Re: No battery voltage readings on DS!
Is the green power light on the Analog Breakout board itself brightly lit?
Do you have power from the Power Distribution Panel wired directly into it?
Unread 04-02-2013, 22:19
FRC #3039
Yes, The green light is brightly lit and I believe it's also powered from the power distribution board.
Unread 04-02-2013, 22:23
Is the Analog Module labeled NI 9201?
Is the Module in the first cRIO slot?
Unread 04-02-2013, 22:25
FRC #3039
Yes, and Yes.
Unread 04-02-2013, 22:28
Pull the Analog Module out of the chassis and visually inspect the pins in the bottom of the chassis. Look for metal debris or bent pins.
Unread 04-02-2013, 22:31
FRC #3039
We did, and everything seems fine.
Unread 04-02-2013, 22:36
8-slot or 4-slot cRIO?
Unread 04-02-2013, 22:39
FRC #3039
8-slot
Unread 04-02-2013, 22:50
The 8-slot's collect metal dust and debris inside.
If it's a used one, have you cleaned out the case lately?
It should be cleaned each year before being mounted on a new robot.
It does weird things when there is dust inside, so that might be a possible cause.
I assume nothing else is plugged into the Analog ports that might cause a short.
You can test the Breakout with a multimeter to see the battery voltage on the pins you put the jumper on. Measure from the pin to any ground.
Use the multimeter to verify continuity through the jumper in case it isn't really a jumper. (I only say that because I once found a team using a cable connector instead-it didn't work.)
Unread 04-02-2013, 22:51
FRC #3039
I will check on it tomorrow. I appreciate your help.
Unread 05-02-2013, 12:20
Does the imaging tool detect the analog module?
Unread 05-02-2013, 12:23
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
We had this issue a couple years ago. It turned out a programmer had assigned the same analog input used for monitoring battery voltage to a second device.
Unread 05-02-2013, 12:43
That would be Analog Input 8
What the jumper does is steal the signal pin from that analog input for use as the battery detector.
If the jumper is put over the other (inside) pin then analog input 8 acts like a normal input in the alternate analog cRIO module slot.
Opening Analog Module 1's analog input 8 is a no-no because it's already opened by the battery monitor.
Unread 05-02-2013, 13:26
If your program needs to know the battery voltage, there's a handy Get Robot Battery Voltage.vi in the Driver Station function subpalette.
